will this version work with all MUX's?
Thank you so much!
Thank you so much!
Can i SCN Coding with 07.2011
Or is 01.2011 better?
(What is the best DAS Version and what are the differents?)
Are there any Password Generator available like jc recordings newest DAS Password Generator or any Xentry Developer Key Generator?
Is Xentry Keymaker v 1.0 a Xentry Developer Key Generator?
THANK YOU SO MUCH!
So you don't mean off-line coding either but off-line programming? Anyway way off-topic for this thread, shall we try to keep this thread clean, this is one of the most important threads at this section of the DK forum and deserves on-topic discussion (off-topic messages like mine could be deleted).
Dear Sir.
After installed it. It work great except i can't get Addon like before and when i tried to open Internet explorer. It won't work anymore. Look like DAS block the Internet ?
is that correct ?
hello m8,
before you install the Update,you have to delete first the IE8 folder in DVD-->Stardiag!!!
regards
Selefkos
Hi guys,
Installed Zolookas Neu Guide2h
SD 07/2011
PKW (Car) is everything OK
In Sprinder 609 have the message
Fault (28.0)
Internal error:Missing mandatory context field
can someone help me
Thans in advance
I guess you do not mean that IE does not work (can you access EWA NET?) but you don't have internet connectivity? SDNC blocks it unless you configure it e.g. for a WEP key WLAN access point. But if you rename the network filter from the SDNC folder, you would regain normal internet access.
Did you check if the OUBG service was set to manual and stopped? Might be better to leave it that way and install AddOns manually.
Small problem with Xentry 7-2011
fresh XP installation then installed by the following order DAS/XENTRY, WIS STANDALONE, SDMEDIA everything was working. Then installed EPC and now my xentry gives me one error
Anybody knows where this came from?
Cheers
EDIT
Found the solution in another forum sorry for jumping the gun asking.
The solution couldn't be more simple:
Originally Posted by ???
