Results 1 to 9 of 9
    Rito's Avatar
    Default ECU opel 1.3 Advise
    I do ECU 1.3 astra H direct in epron.
    (ecu magneti marelli)
    After I do I check value via OBD and this not change.
    (Show same value)
    Someone know something about this?
    Jun 2011
    bosnia and herzegovina
    hi m8. check value and lift + or _ of battery.
    DK Veteran marte690's Avatar
    Italy
    Quote Originally Posted by Rito View Post
    (Show same value)
    Hi, post the dump
    Fec001's Avatar
    Default mjd???????????
    (Show same value)
    Is it Marelli MJD ECU?
    Rito's Avatar
    Yes it is.
    Read first post..
    Fec001's Avatar
    Cokolo maybe can help you...
    I tried with ecucalcv2 but but nothing changed.....
    Italy
    but the dump ??????? were is ????
    Rito's Avatar
    Quote Originally Posted by marte690 View Post
    Sorry I clear dump After out ecu in car.
    I try know if problem is bad write or bad read???
    Toll write was enigma;
    Tool read was dashfixer;
    DK Veteran jruibarroso's Avatar
    Dark Side of the Moon
    where is the dump from Rito's ECU
    All of my posts are for educational purposes only.
    If this was helpful to you, please press THANKS
