Page 12 of 16 FirstFirst ... 278910111213141516 LastLast
Results 166 to 180 of 240
  1. #166
    Feb 2018
    Glasgow area
    Excellent. Anyone tried the KeyDIY remote with IstaP?
  2. #167
    Oct 2018
    Wow great thread, I came here looking for barcode for a mini valeo remote and got more info than i can shake a stick at, thanks all info appreciated.
  3. #168
    Jan 2018
    CA, USA
    first time trying to make a key for a pre 04 mini with the 2 button remote. transponder was easy and made new key starts car no problem, the issue im having is programing the remote to it.
    now i went to http://www.reeves.tv/mini.html to generate a barcode from the sticker on the remote chip. i used ISTA to input the info on the vehicle, but still couldn't get the remote to work, maybe im imputing the wrong numbers from the barcode if anyone can verify from the image below. and yes before trying i removed position key 1 previous remote so it was FFFF all across and ready for a new key (customer didnt have any working remotes)
    thanks for any help
  4. #169
    Feb 2011
    code 1: *X402EF0402EEFFFI*
    Code 2: *FFFFFFFFBFD10F3*
  5. The Following User Says Thank You to profi For This Useful Post:
    cniksor (2nd November, 2018)
  6. #170
    Jan 2018
    CA, USA
    Thanks for the reply, that is the same code i generated on the website minus the X i had J but i read that it doesn't matter as i don't even have to enter it or the computer doesn't save it.
    from what ISTA tells me, i need to get the 3-8 numbers from top barcode for BASIC code in my case being 402EF0 then ista ask for radom code saying it would be 9-14 on top barcode which is 402EEF, which i entered, now for the 16 digit encryption code it says remove the last 2 digits from the top bar code, and use the 15 and 16th digits and ADD to the bottom barcode MINUS the last 2 digits (including the *), making it FFFFFFFFFBFD10F, which is what i got and used insta to add to the vehicle, i went back and read the vehicle entry for key i programed and vehicle shows i entered the codes (assuming these are correct).
    so if anyone can confirm i entered the correct codes, i can only assume 1. key chip bad (brand new but only have this 1 key), 2. something is wrong with the vehicles antenna.
  7. The Following User Says Thank You to cniksor For This Useful Post:
    r1yamaha (7th April, 2019)
  8. #171
    solarsun's Avatar
    May 2011
    Hello guys,
    i need some help.
    I have this bar code 3B971C on mini remote but in 2nd code last digit is missing.
    bar code : 3B971C
    code1 : X3B971C3B971BFFJ
    code2 : FFFFFFFFC468E3_ (last digit missing)
    Can anyone help to find last digit please ?
    I tested 0 and F not accepted ...
  9. #172
    Quote Originally Posted by solarsun View Post
    Hello guys,
    i need some help.
    bar code : 3B971C
    dont think its mising its a space
  10. The Following User Says Thank You to paul_12345 For This Useful Post:
    solarsun (15th December, 2018)
  11. #173
    solarsun's Avatar
    May 2011
    Quote Originally Posted by paul_12345 View Post
    Hi Paul,
    thank you for your help.
    Normally those with space are 0, but i tested with t300 and didn't accept.
    I will test again and give result soon because customer left.
  12. #174
    misamix's Avatar
    Sep 2016
    Serbia
    can someone give me barcode for 2DCF66?
  13. #175
    Jun 2018
    England
    Quote Originally Posted by misamix View Post
    top barcode is *G2DCF662DCF65FFO*
    bottom barcode is *FFFFFFFFD23099R*
    If i helped please press the thanks button
  14. The Following 2 Users Say Thank You to paulsta For This Useful Post:
    misamix (6th April, 2019), r1yamaha (7th April, 2019)
  15. #176
    Apr 2013
    Portugal
    Hi, please someone can give me barcode for remote mini 3EC510 30/11/05??
    tHANKS
  16. #177
    Nov 2015
    UK
    *G3EC5103EC50FFF?*
    *FFFFFFFFC13AEF?*
    Try the above and advise
  17. #178
    newone's Avatar
    Oct 2016
    Quote Originally Posted by auto12volts View Post
    tHANKS
    2004-2006 use the 3 button remote
  18. #179
    P&D's Avatar
    tHANKS
    The correct codes are
    X3EC5103EC50FFFI
    FFFFFFFFC13AEF3
    Quote Originally Posted by newone View Post
    Thats the date in the sticker i think not the car
    What model - Land Rover rover 75 or BMW
  19. #180
    Mar 2017
    I have tried different excel calculators and the exe software. They all work great and give me correct info. Except one remote which I have the bar code. When compared, does not match.
    Lets see who can figure out. Remote was bought brand new at Land rover here in the USA. I believe Valeo change the algorithm as all my remotes that have worked were built 2014 and older.
    This one below is July 2017
    3FDA20
