Page 14 of 17 FirstFirst ... 491011121314151617 LastLast
Results 196 to 210 of 252
  1. #196
    Mar 2018
    UK
    Today failed to program mini 2002 remote
    MVP failed to connect - What dongle and under what software must use?
    Smart pro connected OK
    Cleared the old remote OK
    Programed new remote OK but the remote not work - I checked the remote is programmed but the info looks different
    I tried 2 genuine remotes second hand from scrap yard and generated the barcodes with Paul software
    Also I can't progeam second remote - Failed to connect - when clear the old remote no problem to connect but after first not possible to connect to try to program second one
    How manny remotes can accept this car?
    This is after programming on one of the remotes
    Bar code - 3269FF
    Paul code - X3269FF3269FEFFX
    FFFFFFFFCD9600V
    After programming Smart Pro showed Remote 1
    _255501052541124FF_
    FFFFFF050105_
  2. #197
    Feb 2018
    Glasgow area
    Quote Originally Posted by Manta1600 View Post
    Bar code - 3269FF
    FFFFFFFFCD9600V
    _255501052541124FF_
    FFFFFF050105_
    You can have up to four remotes.
    What you have there doesn't look right for the barcode.
    MVPro (clone - I use it for one job only, barcode remotes) usually works fine.
    ISTA D is better, but slower and less intuitive.
    Reeves.tv only translates six digit codes into mini barcodes. I understand that they're different for land rover and rover, but Nanocom takes the six digit code anyway, so, that's only an issue on minis.
    You could have a car fault. They're a nightmare to synch up. If there's anything not right, they'll fail. Usual culprit is receiver behind the mirror.
    Autokeys.us remotes with MVPro now work spot on every time if there's no underlying car issue.
    I now keep OE ones for Discovery 2 where you need the six digit code.
  3. The Following User Says Thank You to PixelsFixed For This Useful Post:
    Manta1600 (24th July, 2021)
  4. #198
    Aug 2021
    could i get the full code for my mini
    874248
  5. #199
    Europe
    Basic code: 874248
    Random code: 874247
    Encryption code: FFFFFFFFFF78BDB7
  6. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    NER11 (9th August, 2021)
  7. #200
    P&D's Avatar
    Quote Originally Posted by NER11 View Post
    874248
    There you go pal
  8. The Following User Says Thank You to P&D For This Useful Post:
  9. #201
    Aug 2021
    Quote Originally Posted by P&D View Post
    There you go pal
    Thanks so much for taking the time, i am sorry but i gave you the wrong key Code the correct code is in fact 3F4F2F
  10. #202
    Aug 2021
    Quote Originally Posted by tomvleeuwen View Post
    Basic code: 874248
    Random code: 874247
  11. #203
    P&D's Avatar
    there you go if its a BMW
  12. #204
    Aug 2021
    Thanks yes that all worked now have the key working to lock/unlock the car again.
    Does anyone know how i can change the Vin on the Mini R50 BC1 unit?
  13. #205
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    You’ll have to read 93lc76 from the bc1 and vin can be changed in epp.
  14. #206
    Aug 2021
    Quote Originally Posted by Leeetoyo View Post
    ok thanks for epp is a program to allow me to change the stored Vin?
  15. #207
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    Any suitable programmer will do, like vvdiprog, cg100, orange5 and so on..
  16. #208
    Nov 2017
    Hi. I need help for Mini Cooper bar code please.
    386140 02/10/03
    2E95FF 13/05/02
    Resolved. Thank you.
  17. #209
    Mar 2018
    UK
    This fu--ing sh-t make me crazy
    02 Mini the original remote not work
    Tried to program 3 genuine remotes with codes generated with Paul software with X letter - no success
    Generated KD remote and KD give me codes with N that must be for Rover - I Programmed the remote and the remote work fine
    after that generated N codes for one genuine remote and programmed to the car on possition 2 - genuine not work - KD still work but not properly must press few time the buttons
    Cleared again all remotes and programmed the KD on possition 1 not work any more - tried few times to reprogram without success
    Few things that I noticed when must press the buttons to program the remote there is not respond from car like cycling the central locking - I had only one respond when I programmed the KD successfuly
    When smart pro is connected the windows not work
  18. The Following User Says Thank You to Manta1600 For This Useful Post:
    Kittenjockey (26th July, 2022)
  19. #210
    Failed to program on R50 2003 Japan market.
    I brought 226750, so random code should be 22674F encryption code FFFFFFFFFFDD98AF.
    Not work.
    I read out the original remote code by IM608,
    Base code 36334B
    Random code 36D1A8(Not -1)
    Encryption code FFFFFFFFFFC9CCB4 (=FFFFFFFFFFFFFF-36334B)
    Another random code calculation?
