Page 3 of 17 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 252
  1. #31
    Hi myexige
    Could you do this one for a Mini:
    3A1312
  2. #32
    west mids, uk
    hi mate, so all these remotes will work on mini, rover and lr, but the code needed is different?
    cheers, ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  3. #33
    Quote Originally Posted by ninja123 View Post
    cheers, ninja
    Yep, thats correct
  4. #34
    Quote Originally Posted by MrSporty View Post
    Hi myexige
    3A1312
    Code for the mini is
    *X3A13123A1311FFG*
    *FFFFFFFFC5ECEDI*
  5. The Following User Says Thank You to myexige For This Useful Post:
    MrSporty (16th February, 2014)
  6. #35
    May 2009
    Hi myexige
    Please help for a Mini:
    38866E
    08/10/03
  7. #36
    *X38866E38866DFFN*
    *FFFFFFFFC77991-*
  8. #37
    malczykos's Avatar
    POLAND
    Please BAR CODE:
    For Rover 75 and for Mini
    1.
    356739
    15/05/03
    2.
    3E5EF8
    25/03/05
    3.
    28A46F
    07/03/01
    4.
    3EDB72
    16/01/06
    5. This is for MINI
    24902C
    02/12/99
    THANX
  9. #38
    Quote Originally Posted by malczykos View Post
    Please BAR CODE:
    1.
    356739
    15/05/03
    2.
    3E5EF8
    25/03/05
    3.
    28A46F
    07/03/01
    4.
    3EDB72
    16/01/06
    5. This is for MINI
    24902C
    02/12/99
    THANX
    1.
    356739
    15/05/03
    *N356739356738FFW*
    *FFFFFFFFCA98C65*
    2.
    3E5EF8
    25/03/05
    *N3E5EF83E5EF7FF+*
    *FFFFFFFFC1A107M*
    3.
    28A46F
    07/03/01
    *N28A46F28A46EFFD*
    *FFFFFFFFD75B90-*
    4.
    3EDB72
    16/01/06
    *N3EDB723EDB71FFN*
    *FFFFFFFFC1248DV*
    5. This is for MINI
    24902C
    02/12/99
    *X24902C24902BFFY*
    *FFFFFFFFDB6FD39*
    Hmmm i do think this amount may be taking the p*ss slighty!
  10. #39
    malczykos's Avatar
    POLAND
    Thank you very much.
    I tested and report.
  11. #40
    Would I be correct in saying anyone can change the code to mini/rover by just changing the X->N N->X without changing the checksum.
    Also can the checksum be any printable char or just numbers and uppercase letters I assume - 'o' and -+? or is that saying too much
  12. #41
    No, not correct, the checksum does change too.
    It can be 0-9, a-z plus a few others including a space character!
    You need different codes for UK MGR, LR, Mini, different codes for Non UK MGR,LR and Mini, different codes if they are 433Mhz or 315Mhz versions and a different code for LR SLS remote!
  13. #42
    Well I'm bored trying to figure it out so will post what I've found.
    take the example
    24902C
    02/12/99
    *X24902C24902BFFY*
    *FFFFFFFFDB6FD39*
    First letter of the first line represents the car make.
    The next 3 bytes are the code from the label
    24902C
    The next 3 bytes are the code again -1
    The next byte seems to be always FF.
    The last char I assume is a checksum for the first line??
    The bottom string is FFFFFFFFFFFFFF minus the code from the label in this case FFFFFFFFFFFFFF - 24902C = FFFFFFFFDB6FD3 then the last char I assume the checksum.
    I did think the FF were there to pad the first string to 7 bytes for checksum use, and that one bit could be taken from each byte giving a max value of 0..127 which could be represented by all the printable characters but may be not
  14. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    armpower (8th April, 2016), nyandacca (5th January, 2022)
  15. #43
    DK Veteran gtmech's Avatar
    Hell
    Fantastic post paul_12345, keep up the good work, thanks for sharing
    Quote Originally Posted by paul_12345 View Post
    take the example
    24902C
    02/12/99
    *X24902C24902BFFY*
    *FFFFFFFFDB6FD39*
    24902C
  16. #44
    Hollywood
    đđĐđß$đĐßđßđßđđääđłldkf>>;*;ßßߤߤ;>>;>ßߤ]$ß$÷÷×ßß]¤¤¤]ß$$[ß[¤ĐĐß[ß...
  17. #45
    malczykos's Avatar
    POLAND
    I confirm, codes 100% OK. Tested on the MINI.
