Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    LaraVAG's Avatar
    Jun 2011
    Poland
    Swiftec correct romove dpf in Passat!
  2. #17
    LaraVAG's Avatar
    Jun 2011
    Poland
    test many times! If you dont have original softwer like swiftec, how can you now that it isnt work??!! Swiftec in many case disable dpf by switch in that car too!
  3. #18
    Jan 2010
    Quote Originally Posted by LaraVAG View Post
    Can you help me?
    I haven't swiftec soft.
    This is the full dump with bdm.
    thanks cseko
  4. #19
    skywoker's Avatar
    May 2012
    ROMANIA
    Default Passat DPF OFF
    Your file dpf off. Pass in PM
  5. #20
    Jan 2014
    Usa
  6. #21
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Where you live? March,2012 ?
  7. #22
    Feb 2012
    romania
    I can help me someone canceled particulate filter in 2004 passat? MPPs is read
    2.0 tdi passat dpf off.rar
  8. #23
    Aug 2011
    Quote Originally Posted by cristecristian View Post
    Dpf off, pass in pm.
    If error Code software incompatible then disconnect all dpf sensor (diff. press ,temp ).
  9. The Following User Says Thank You to tarts1999 For This Useful Post:
    cristecristian (13th October, 2014)
  10. #24
    Feb 2012
    romania
    Thank you, tarts1999 , worked perfectly
  11. #25
    Mar 2010
    Hello friends ,
    I have a 2005 vw passat 3b 2.0 TDI-PD 136 hp.I want to make dpf off and hot start fix and i have read the edc 16 with mpps . I have read in two ways ,mean data area and full read.
