Hi, will this work ok with the star view 9600 caci as I wouldn't want to wreck the box with incorrect firmware
Thank you![]()
Thank you![]()
Hi, is it a serial straight through cable or a null serial cable that I require, thanks![]()
is there a file for hd combo to have spiderbox 9900hd firmware that can be loaded, tried the 9900 rs232 and it is stuck on 'writing software to flash' thanks
Hi, just fired up starveiw hd combo, was using with cable, but now have sat dish, is this the firmware i need? new to all this.
Thx in advance
Once upon a time it was all about backdoor 0 passwords, now its only about the rsa keys !!!!!!!
If this post has helped you........... Don't be shy and hit the Thanks button..
Mvison firmware works fine with the starview 9600 caci...as suggested by bytemaster leave the network and stuff on and it will work fine...otherwise you get an unknown on the menu!...
Hi I got starview hd combo lan which was being used on cable but now not working. Decided to try it on sat side but keeps freezing and saying "scrambled channel". Will this help.
Does anyone have a picture of what this should look like on the Starview HD Combo + as the 1st time I tried to load it it seemed to fail ad the 2nd time it went on but I still think it has not worked as see no difference.
Hi guys. Ive read that some people have connected their pc via USB to rs-232 on Starview box and have been successful in installing this firmware. I have followed the instruction correctly however I did connect via com4 because my cable is connected to com4 on my laptop. Everything goes well until up the point where I turn on the Starview box...nothing happens. The flash tool does not take over the Starview box and does not do anything. The bar on the program jut stays at 0%. Can someone please give me some advice. Thank you
thanks! gonna check it out now
Spider box works fine with patches. But how do i access the cc4am setting with this firmware?
Can anybody tell me if there is something on the spider sw i should be doing?
