Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
  1. #16
    Nov 2011
    Hi, will this work ok with the star view 9600 caci as I wouldn't want to wreck the box with incorrect firmware
    Thank you
  2. #17
    Nov 2011
    Hi, is it a serial straight through cable or a null serial cable that I require, thanks
  3. #18
    Mar 2010
    is there a file for hd combo to have spiderbox 9900hd firmware that can be loaded, tried the 9900 rs232 and it is stuck on 'writing software to flash' thanks
  4. #19
    Sep 2009
    Quote Originally Posted by jakeemate View Post
    Thank you
    Yes it works fine on the Starview caci....
    Im trying out the mvison version....how do I get the CCam menu up after putting the patch on?
    whats the remote control code!
  5. #20
    Sep 2009
    Quote Originally Posted by maxvee View Post
    use a null modem cable and make sure you select the correct port ..mine was on com 2
  6. #21
    Mar 2010
    Quote Originally Posted by kam View Post
    Its a firmware issue, as the spiderbox 9000 flashes and the 9900hd gets stuck on 'writing to flash' question was if the rs232 firmware for starview hd combo could be modified so that it becomes a spiderbox 9900hd.. cheers
  7. #22
    Dec 2011
    Hi, just fired up starveiw hd combo, was using with cable, but now have sat dish, is this the firmware i need? new to all this.
    Thx in advance
  8. #23
    Top Poster + ByteMaster's Avatar
    Sep 2010
    London
    I think it's 2121 but if not reload the spider firmware. Switch on the network 1111 then load mvision. Network remains on and all your lines will be there also
    Once upon a time it was all about backdoor 0 passwords, now its only about the rsa keys !!!!!!!
    If this post has helped you........... Don't be shy and hit the Thanks button..
  9. #24
    Sep 2009
    Mvison firmware works fine with the starview 9600 caci...as suggested by bytemaster leave the network and stuff on and it will work fine...otherwise you get an unknown on the menu!...
  10. #25
    Jan 2012
    Hi I got starview hd combo lan which was being used on cable but now not working. Decided to try it on sat side but keeps freezing and saying "scrambled channel". Will this help.
  11. #26
    Nov 2008
    Quote Originally Posted by philipo22 View Post
    no , freezing is usually a srvr issue , not a firmware issue
  12. #27
    Dec 2009
    Thumbs down How long does the loader take?
    Does anyone have a picture of what this should look like on the Starview HD Combo + as the 1st time I tried to load it it seemed to fail ad the 2nd time it went on but I still think it has not worked as see no difference.
  13. #28
    Apr 2012
    Hi guys. Ive read that some people have connected their pc via USB to rs-232 on Starview box and have been successful in installing this firmware. I have followed the instruction correctly however I did connect via com4 because my cable is connected to com4 on my laptop. Everything goes well until up the point where I turn on the Starview box...nothing happens. The flash tool does not take over the Starview box and does not do anything. The bar on the program jut stays at 0%. Can someone please give me some advice. Thank you
  14. #29
    Aug 2012
    thanks! gonna check it out now
  15. #30
    Nov 2008
    Spider box works fine with patches. But how do i access the cc4am setting with this firmware?
    Can anybody tell me if there is something on the spider sw i should be doing?
