What engine is inside?
HI,
i've searched through so far only found W211 pinout.
Could you please provide me the info of mercedes W210 cluster pinout ?
Only 12v and GND needed. I am going to power them with my 12v laptop charger, to repair the LCD...
PS. i've tested the laptop charger to power up W211 cluster and it works ! You guys can do the same too.
I will press thanks button 10 times !!!
Thank you !!
Last edited by sss123456; 14th September, 2011 at 02:30 PM. Reason: upload dash pic
Connector A (18 pin)
pin 11: + battery
pin 9 : + Ignition
pin 3 and 12 : -GND
I have no idea wht engine because only received dashboard.
the dash serial is 210 540 95 47, manufactured in 1998, only one LCD at the center.
i have the same like LoRaier
http://imageshack.us/photo/my-images/853/mercedesr.jpg/
if it wont work search topic for mercedes a class 2000 pinout on this forum.
There's attachment with a pinout database.
I hope this would help
capi (13th October, 2015), jevgensolo (19th March, 2018), mexanico1971 (1st December, 2013), _estima_ (22nd January, 2018)
Hello everyone;
I'm in the process to install an aftermarket cruise control unit in an old but good E290TD; i'm doing an aftermarket installation since it has manual gearbox and was not possible to install the stock unit (available only with automatic gearbox..). The electromechanical actator is installed as per mfg instructions and so far it look good, but I still have to finish the electrical istallation, and in particular I need toget some info about the VSS.
Where I can get VSS signal on the W210? so fat I was thinking to split the signal fro one of the phonic wheel (front left so it's close to the actuator unit..) or take the speed signal from the stock radio connector (plug A, pin 1; black-green wire).
Anyway even in case of that I need the type of wave (square or sinusoidal) and the pulse per mile (PPM) (of course PPK, pulse per km is good too ).
Of course the best would be to take the signal that goes to the instrument cluster but I have no idea about wich pin and wich of the two connectors has it, so I hope to get better info here.
Thanks in advance for the cooperation.
Cheers
Daniele
I have the same problem with dashboard, display dont work, anybody know which is the problem? or how can i dump the memory on other dashboard?
Very thanksssss
