Results 1 to 10 of 10
    Nov 2010
    Default VW B5 1.9tdi hot start problem
    Hello
    I need fix hot start problem
    VW Passat B5 1.9tdi AVB 74kw
    netherlands
    here you go..
    Last edited by sjonv; 14th September, 2011 at 09:13 PM. Reason: forgot the attachment
    Nov 2010
    Better now
    Passat start always now But need 6-12 cranks
    Before was very difficult start
    May be is posiible better fix?
    warm boot problem occurs not in the longitudinally mounted engines, so it certainly does not help flash hot start fix
    workshop
    i have trouble with touran 1,9 tdi
    bad hot start,can you for me check flash?
    thx.
    ALGERIA
    Quote Originally Posted by mercis View Post
    thx.
    did you trayed other ecu and the probleme was solved?
    becose i see that your dump is 100% original!!!
    how an original dump can be a probleme??!!
    @mercis,you file here :
    netherlands
    Quote Originally Posted by bsv2001 View Post
    Better now
    i dont understand you,
    do you mean that the car before you writed my dump didnt start?
    And now it needs longs starting?
    did you read dtc? maybe tempature sender defect or something with starter...
    Nov 2010
    B5 didnt have DTC in ECU before and after fix hot start problem
    All sensors rates are correct
    VW B5 could start some days nice and after B5 could not start -only with towing
    With towing-always start nice
    We check all with donor VW B5
    After fix this problem - B5 start always But sometime with 6-10 crank
    Sep 2011
    Baltic States
    You have motor defect!!!!
