Results 1 to 13 of 13
    Apr 2011
    Lithuania
    Default sharan edc16u31 dpf-off
    HELLO, please help me. i have VW sharan 2.0 102kw. i need disable DPF/FAP FILTER.
    ECU BOSCH EDC16U31
    0 281 012 696, 03G 906 016 JP
    ecu safe don`t make this ecu, read with CMD 1255
    THANK YOU
    Apr 2011
    Lithuania
    Default SHARAN
    it`s dumps
  3. The Following User Says Thank You to skironas For This Useful Post:
    professzor (15th November, 2016)
    levisdj's Avatar
    EcuLand
    Try this and rep.
    Jun 2009
    Try this and post result
    CS OK
  6. The Following User Says Thank You to chli1976 For This Useful Post:
    ACDC (14th June, 2013)
    Apr 2011
    Lithuania
    Default sharan
    Quote Originally Posted by levisdj View Post
    Try this and rep.
    thank you, but engine not run
  8. #6
    Apr 2011
    Lithuania
    Quote Originally Posted by chli1976 View Post
    CS OK
    thank you very much, now engine RUN.
  9. #7
    levisdj's Avatar
    EcuLand
    you needed to calculate CS!
  10. #8
    Apr 2011
    Lithuania
    Default sharan
    cs calculated CHLI1976
    thank you
  11. #9
    Belarus
    chli1976,please help me with pass for you flash orig off.rar
  12. #10
    somewhere
    CS OK
    Hi.
    Please send me the pw!
    Thank you friend!
  13. #11
    somewhere
    Hello friends!
    I need dpf remove edc16u31 ecu (sharan 2.0 pdtdi).
    Please help!
    File: sharan.zip download - 2shared
    I can't upload here!
  14. #12
    Sep 2011
    Belarus
    Quote Originally Posted by gixerke View Post
    Hello friends!
    Please help!
    you need correct dpf off manually. I can help you
    here your dpf off file
  15. #13
    File error, can you send me this file on PM
    Quote Originally Posted by magictuners View Post
