Fault found
02818-steering column lock:enabling for Electronic ignition lock,006 short to plus-intertiment
02811-control module for steering column lock,014 Defective
On this car, steering is light yellow, and does not start, if I delete these error codes, the car starts, and no, there are problems 3-4 days, then, and the bulb lights, the car does not start.Can repair the steering column module?If you do immo off, solve the problem?Thanks!
