Aprilia Pegaso 650 Year 2007
Aprilia Strada 650
CONECTOR 40 PINS
Pin1 +12v Key
Pin11 +12v battery
Pin20 -12V ground
Attachment 814959
Aprilia Strada 650
CONECTOR 40 PINS
Pin1 +12v Key
Pin11 +12v battery
Pin20 -12V ground
Attachment 814959
skens (9th July, 2021)
I need pinout for this dashboard from Nissan Primera
i need pinout vespa perima 2020
Sent from my SM-G998B using Tapatalk
Can someone help me pinout Toyota RUSH 2012 ??
Thanks mate
HI
pinout xmax 2019
pin 2 , 8 +12v
pin 3 ,4 GND
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Hi DK family..
Hope all is well today ..
Please can someone help me to power up ford bantam facelift cluster on the bench . Not sure if the cluster is faulty or if it's a wiring issue .
No mileage display ,no gauges that work .only battery and oil light come on and then go off once car has started .nothing else ...
Any help on this would be much appreciated
Thanking you in advance
solved ..thanx guys ,wiring fault ...
Maybe someone need it
here is a contribution
if you think i helped youkindly press REP+THANKS button
fuzz1 (20th June, 2021)
hello mates, this is Peugeot Expert, I am not able to power up, anyone canhelp me pliz??
Either of these should do it
[QUOTE=McDowell;4151292]5fadeb2d-b84c-47de-8c4c-e37fa4090163.jpg499eed6e-927b-4961-a4c4-1f7eebb86fc4.jpg
hi
good luck
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
McDowell (25th June, 2021)
Here's a pinout for the Gen2 Prius combination meter. I've flipped the connector view so it's like looking at the connector with the board out. I've also compiled some information on how to edit the EEPROM to adjust the mileage on my website. There's also a pinout for the EEPROM connections to the test points on the back of the board so you don't need to waste time de-soldering the LCD to get to the EEPROM chip. Reading this board has helped me a lot, so hopefully this will help someone new.
dashradio (26th June, 2021), Duwagemadusanka (21st November, 2022), MileageAudit5 (16th August, 2021), yuka (16th January, 2025)
