Page 128 of 149 FirstFirst ... 2878118123124125126127128129130131132133138 ... LastLast
Results 1,906 to 1,920 of 2224
  1. #1906
    Jul 2022
    Help With HB20 2016 cluster power up or pinout... I disassembled it, and donīt have one single silk text on this board.. so, no clue...
    Labels on it:
    HB PE A2C97 156904 *SV01040816* 94023 18000 A2C97980400
    * Added a picture from connector, from internet. Wondering where is canbus L and H, and power...
    some pics of this model:
  2. #1907
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by sellersjc View Post
    Labels on it:
    Check if this helps / work.
    I didnt tested. i just check some manuals i have and that was what came up.
    If it works leave a comment confirming...
    Cheers
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  3. The Following User Says Thank You to boxsport For This Useful Post:
    sellersjc (6th July, 2022)
  4. #1908
    Jul 2022
    Amazing. Iīll try and come with results.
    #edit
    No success.
    #edit 2
    I try to power pins 36 as GND, 33 and 29 as +12v. The cluster rotates the needles to initial position, but nothing more. Guessing using this image...
  5. #1909
    Jul 2022
    ok, so far:
    36 = GND
    33 = +12v
    7 = left signal, +12v
    8 = right signal, +12v
    11 = fog, 12v
    14 = trunk, gnd
    15 = door, gnd
    31 = immo, gnd
    40 = lights, 12v
    so far, no back lighting or display or anything else.. donīt wake up yet.
    #edit muhahahahaha i did it. Is lit. testing pin by pin.. lucky me i did not burn it.
    Now... can-bus i have no idea even how to find it. But i need to .
    I hope my effort helps someone, Here in Brazil are so hard to get some info...
  6. #1910
    Sep 2016
    Hi.
    I need pinout dash for Suzuki Leana,Aerio 2006 no digital.
  7. #1911
    Apr 2019
    Power Up Toyota Rush / Daihatsu Terios MY 2019.
    Red ===> +12V Batt.
    Orange ===> Ignition Switch (+12V).
    Black ===> Ground.
    ###Don't forget to add Rep & Thanks###
  8. The Following 3 Users Say Thank You to rybenz For This Useful Post:
    dashradio (27th July, 2022), McDowell (29th July, 2022), rtbdiagnostic (26th July, 2022)
  9. #1912
    commieTH's Avatar
    Jun 2016
    Thailand
    Looking for power up and/or in-circuit solder points for this 2016 Civic, can anyone help please?
  10. #1913
    skens's Avatar
    Zagreb,Croatia
    hi
    have 2015
    good luck
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  11. The Following User Says Thank You to skens For This Useful Post:
  12. #1914
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default VW Polo 6n power up
    Need power up for a 1998 VW Polo Playa
    'If I helped, please click Thanks +Reputation.. !'
  13. #1915
    skens's Avatar
    Zagreb,Croatia
    hi
    like golf 3
    5 GND
    11,13 +12v
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  14. The Following User Says Thank You to skens For This Useful Post:
    rtbdiagnostic (28th July, 2022)
  15. #1916
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hello all i am after this mercedes truck power up pinout
    see attach-
    45b16c46-62b2-48d8-abf9-1510c545eb80.jpg58cc9385-6fbf-43cb-9c27-97bc2bab8c41.jpg7200ecc4-5ea0-4729-b6f8-af5c94b520bd.jpg
    and by the way...dash is dead. i know is a common problem if somebody can help me.
    Thanks all in advance,.
  16. #1917
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by commieTH View Post
    here br,,enjoy......
    if you think i helped youkindly press REP+THANKS button
  17. #1918
    Ireland
    Astra J
    I found in previous posts power up information (16 GND,31 +12,32 +12
    Does anyone know where the CAN's is in this connector?
    ==== SORTED ===
    26 0.5 D-GN 5060 Low Speed GMLAN Serial Data
    27 0.5 D-GN 5060 Low Speed GMLAN Serial Data (D8G, KA1, TQ5, UD5, UD7, UVT, or VQ9)
  18. #1919
    Nov 2015
    Hi. Does anybody have pinout for powerup on bench for Mercedes W202 cluster
    110.008.558/044
    If I did help, please use thanks buttons!
  19. #1920
    tazz75's Avatar
    Nov 2018
    Default Mercedes benz W204 cluster pinout
    Hy all..can anyone help me pls with pinout for this dash ?
    Thx in advance
