here is one for nissan Rouge cluster pinout
cj
cj
anyone have the the pin-out to power up the current 2014 rav4 cluster it has the micro 93c66 eeprom
digger75 (15th March, 2016)
Request power Up for Toyota Yaris or Vitz 2011-2012:
Honda VFR 800 little be old but maybe someone need
Pin 2 +12v
PIn3 -GND
Request power Up for Toyota Passo 2010:
Undress right pic .. i mean remove white cover ..
Course, there:
The pins all those diodes connect to are very likely to be ignition and battery (all 7 group off 2 pins), then do a continuity test between C29's negative pin and the plug and will find your negative,
Yes use a multimeter with beeb or ..
Either, the beeper will definatly help you find a ground pin much faster,
Thanks, but this Power up for old Dash
Does anyone have citro?n Picasso dash pinout? It's VDO with just one blue connector
Thanks in advance
i need nissan navara 2011 uk model dash power up thnx
never lost anythink only change ...
