Please help me
need Gilera Runner sp power up
Please help me
Here you are pin out for the cluster from BMW F30 2012
Johnson Controls
Pin 2-GND
pin 8-12v
pin 6-C L
pin 12-C H
To see mileage or kilometers you need to press the button at the front/left bottom corner.
Hi all. Please need help to power up volvo v70 dash. Thanks for your time.
Sent from my SM-G925F using Tapatalk
Hi.
You can't power up Volvo dash without CAN emulator.
lush29 (3rd May, 2016)
Hello ,
need pinout dashboard TOYOTA YARIS 2014 and DACIA LOGAN 2015
Thanx in advance for your help .
Dacia-Renault (Logan / Sandero) memory 25020.
CONNECTOR (24-way Black) track Description
1 Handle locking witness software
2 Witness water temperature
3 Not used
4 LED failure antipollution
5 Witness rear fog lights
6 Witness headlights fog
7 Ground
8 Signal - fuel gauge
9 Power + Battery
10 Power after contact
11 Power + sidelights
12 Signal + water temperature
13 Witness battery charge
14 oil pressure warning
15 Witness direction indicator
16 Witness hand brake + level liquid
17 Witness heated rear window
18 Witness road lights
19 Witness dipped headlights
20 airbag fault warning light
21 cuentavueltas Signal
22 Signal vehicle speed
23 Command Parade (computer to board)
24 Signal + fuel level
CONNECTOR (24-way gray)
The gray 24-way connector is mounted only on the MG and HG versions.
track Description
1 Not used
2 Not used
3 inhibition airbag Witness passenger
4 Not used
5 Not used
6 Not used
7 Not used
8 Not used
9 Not used
10 No used
11 Not used
12 open door Witness
13 Weight (without ABS)
Witness delivery failure Electronic braking(With ABS)
14 Not used
15 Not used
16 Weight (without ABS)
Witness failure ABS (with ABS)
17 Not used
18 Not used
19 Signal info consumption fuel
20 Not used
21 Not used
22 Not used
23 Not used
24 Not used
anyone have the power pinout for a 2007 mini cooper
Honda Hornet 600cc
My first contribution!
Subaru Legacy MY10 BM/BR (2009-2013) 93c76 (Outback, Liberty will be same)
19 & 20 12v
39 & 40 GND
clusters (26th May, 2016), hoangtu (7th June, 2016), panderetamix (17th December, 2020)
prius 2010 power
12-14 Subaru Impreza, PowerUp PinOuts, 93C76
DON'T JUST SAYPRESS IT.....
CASE tractor MX120-MX130-MX135-MX150-MX170 powerup pinouts
Here is the connection for JCP
Nothing will remain in this World , Everything will come to END!
THINK POSITIVE NOTHING IS IMPOSSIBLE
Please do not spam by PM asking for help. Use forum, that is why we are here.
