Does someone has the pinout for old Mercedes S-Class ?
Power pin and speedo pin will be also enough :-)
regards
regards
Looking for 2005 audi a4 power up - pinout.
Audi A4 2002-2007
Green connector :
1 - Terminal 58d
2 - Terminal 30
3 - Terminal 15
4 - Not assigned
5 - Speedometer input
6 - Speedometer output 2
7 - Airbag inverse
8 - Right turn signal
9 - Low brake fluid level
10 - Left turn signal
11 - Trailer turn signal
12 - CAN powertrain low
13 - CAN powertrain high
14 - Terminal 61/charge indicator
15 - Not assigned
16 - Oil pressure 2
17 - Terminal 58s
18 - Terminal 31 load
19 - Terminal 31 load
20 - Not assigned
21 - Speedometer output 1
22 - ABS warning
23 - K-wire
24 - CAN powertrain screen
25 - Tank cap switch
26 - CAN-Diagnostic low
27 - CAN-Diagnostic screen
28 - CAN-Diagnostic high
29 - Automatic vertical headlight aim control system
30 - Belt buckle
31 - Outside buzzer
32 - Brake pad wear
Blue connector :
1 - Low washer fluid level
2 - Low coolant level
3 - Fuel gauge sensor
4 - Coolant temperature
5 - Push button circuit 2, navigation
6 - Push button circuit 3, navigation
7 - Push button circuit, Telematics
8 - Menu switch
9 - Not assigned
10 - Hood switch
11 - Fuel gauge sensor 2 (Quattro)
12 - Menu selection switch (out A)
13 - Not assigned
14 - Not assigned
15 - Not assigned
16 - FDR/ASR (= ESP)
17 - CAN comfort high
18 - CAN comfort low
19 - CAN Infotainment low
20 - CAN Infotainment high
21 - Outside temperature -input
22 - S-contact
23 - Oil level/oil temperature
24 - Level control
25 - Menu switch (Enter)
26 - Not assigned
27 - Not assigned
28 - Menu switch (out B)
29 - Not assigned
30 - Transponder 2
31 - Transponder 1
32 - Terminal 31 (sensor)
Smart 98-2002
Eprom inside 93C66 x16
+12V=6,7,8
GND= 9
I am looking for Volvo C30 2008 dash power up.....thanks
Hope this helps Volvo C30
cjawahir (13th December, 2017), gsmflasch (18th December, 2017), jomberykaso (12th December, 2017), skens (21st December, 2017)
help
how conect
suzuki sv650
I need power pins for renault master 3 thank you in advance
Not sure if it has been covered but if not here it is
2008 FORD ECONOLINE VAN E150 E250 E350SD*
2 connectors
26 pin connector =
PIN 1+ (positive)
PIN 2+ (positive)
PIN 14 - (negative)
18 pin connector =
PIN 5 + (positive)
PIN 10 - (negative)
* = Cluster will light up but miles will not show. it will read ------
MasterCodein (1st August, 2020), MileageAudit5 (26th March, 2020)
Also Looking for pinout of pre2002 (1996-2002) Audi clusters like these:
borshch (4th January, 2018), Cbrcluster (18th April, 2020), cjawahir (2nd January, 2018), line44 (9th July, 2019), multiexpress (10th May, 2018), pedrod2005 (29th June, 2020), vego20 (24th March, 2018)
wrong thread. deleted.
I am looking for renault modus j77 mg ess fs, 2811984802, ns0203171-3 , thankyou
Honda CBR1000RR 2008
r1yamaha (18th November, 2024)
