2000 VW Beetle Dash /
xc525099cpv chip read like 68hc9s12d60 Beetle cluster connection
capi (26th September, 2020), cjawahir (15th January, 2020), keysmith (24th March, 2021), pokusmaster (14th November, 2022), rtbdiagnostic (28th February, 2018), teo21 (26th February, 2018)
needed the connections for dashboard mazda bt 50 2006/2007
Hi guys! I have a VDO Golf 6 cluster and I want tu read it with VCDS . I connected pins 31 32 to +12v ,pin 16 to ground and 28 can high, 29 can low (these are the cluster's pins); at the Vag Com obd2 interface I connected pin 4 to gnd , pin 16 to +12v and pin 6 can high, pin 14 can low (connected with pin 28 and pin 29 from cluster) but I can't read them . Is there anything else I should connect? Thank you in advance and sorry for the off topic !
Try this
looking for 2004 ford freestyle pinout / power up
maybe anyone has gathered collection in one link or rar?and could share ,can to pm too.
Toyota Yaris 2004
regards
capi (26th September, 2020), JotaB (3rd October, 2022), pedrod2005 (20th July, 2020), vasa (10th March, 2018), _estima_ (28th July, 2018)
Anyone has a connection to power up this ISUZU DMAX
Sent from my SM-J710GN using Tapatalk
if you think i helped youkindly press REP+THANKS button
isuzu dmax 2009 check pin 1 is ground and pin 8 is +12VOLTS .
notice the numbers on the 16 pin connector where its solder to the pcb .
cj
2013 Kia Soul power up. Pictures of the unit.2018-03-13 11.01.30.jpg 2018-03-13 11.01.11.jpg2018-03-13 11.04.17.jpg Thanks for the help.
Stelaras26 (14th March, 2018), tfourk (3rd October, 2019)
rtbdiagnostic (15th June, 2021)
suzuki alto need power up
never lost anythink only change ...
Anyone has a power up pinout for Fiat Brava 2001 cluster?
Send picture from back of cluster to see connector. It is cluster with ST ?
It is this kind ?
