alclot (17th July, 2018)
Hi mates. Other cluster. It is from BIKE APRILIA ARRECIFE 500 year 2002. Can I have power up here?
Thanks in advance![]()
Stecker A
(20 Pin)1 2 3 4 5 6 7 8 9 10 Geschwindig-keitssignal 50Hz = 60Km/h 11 12 13 14 15 Standlicht 16 17 18 19 20 Kl. 30
Stecker B
(16 Pin)1 Warnblinker 2 Blinker links 3 Blinker rechts 4 5 6 7 Kl. 31 8 Kl. 31 9 10 11 12 13 14 Drehzahlsignal 15 Kl. 30 16 Kl. 30
try this..![]()
alclot (19th July, 2018)
Please, need power up for Toyota Yaris 2006 dash (Japan).
Two plug: 16pin and 24pin.yaris japan.jpg
SOLVED: PIN 1 - 12V
PIN 24 - GND
_estima_ (15th November, 2018)
Pinout Yamaha FZ1 Fazer
ACCENT BLUE- ACCENT VERNA 2012- 26C16
Do someone have the power up BMW F10 pinout ?
Pls send me the file with 0000km because of engine changed.
if you think i helped youkindly press REP+THANKS button
Thank you for Reply.
Hi mates,
Here cluster from John deere 5510N year 2003. Can I have power up?
Stecker D / X01 links
(18 Pin)
1 Tank 2 Kühlwassertemp. 3 Drehzahl 160 Hz = 1000 U/min (min. 1Vpp) 4 Geschwindigkeits- signal O.C.
ca. 1520Hz bei 30km/h
Schiltrac:
Rechteck 500Hz = 41km/h (12Vpp)5 6 7 8 Standlicht Anzeige + 9 10 Zapfwelle Anzeige + 11 12 13 Hydraulik- Warnung + 14 15 Gelbe Warnlampe + 16 Volllicht Infolampe + 17 Kl. 31 18
Stecker L / X02 rechts
(12 Pin)
1 Kl. 30 2 Kl. 15 3 Beleuchtung + 4 5 6 7 8 Standlicht 9 10 11 12
here mate..
alclot (23rd July, 2018)
Hi Bidu. This powqer up is not correct. Can you check it please?
Thank you very much bro![]()
