Page 74 of 149 FirstFirst ... 2464697071727374757677787984124 ... LastLast
Results 1,096 to 1,110 of 2225
  1. #1096
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by Marvinnn View Post
    pin5 -> 12V
    pin7 -> 12V
    pin8 -> gnd
    Orig table 2nd column is empty.
    Sorry, now I see it. Yes, that's so correct
    Don't forget the magic button !
  2. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (29th October, 2018)
  3. #1097
    Oct 2018
    Hy,
    The green connector pin24 not K-line.
    How to wiring green connector?
  4. #1098
    Oct 2018
    Please 5j0920840C dashboard green connector wiring diagram or k-line number or how to connect (not replace dash in car) vcds.
    I try pin 24, 23, 25 k-line connect vcds but not response dashboard.
    Can-h and can-l connect or k-line?
  5. #1099
    bidu20's Avatar
    Jun 2016
  6. The Following 3 Users Say Thank You to bidu20 For This Useful Post:
    alclot (30th October, 2018), Marvinnn (30th October, 2018), Perryking (1st November, 2018)
  7. #1100
    alclot's Avatar
    Melee Island
    Hi mates,
    Can I have power up here please?
    Renault clio year 1998
    thanks in advance
  8. #1101
    bidu20's Avatar
    Jun 2016
    Renault Clio 1998
    Stecker N
    4
    5
    6
    7 Drehzahl 33Hz = 1000U/min
    8 Geschwindig-keitssignal 79Hz = 60Km/h
    160Hz = 120Km/h
    9
    10
    Stecker M
    1 Kl. 31
    2 Tank 10Ω = voll
    300Ω = leer
    3 Kl. 30
    4 Mode Bordcomputer Kl. 31
    5
    6
    7
    8
    9
    10 Kl. 15
    Stecker G
    4
    5 Kl. 15
    6
    7
    8
    9
    10 Kl. 31
    A little different version, but should be the same
    Stecker C
    1 Beleuchtung Totali Kl. 31
    2 Motortemperat. 30Ω = heiss
    3 Kl. 58
    4
    5
    6
    7
    8
    9
    10
  9. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (31st October, 2018)
  10. #1102
    jurroid13
    Guest
    do not use antivirus for about 5 years,and I advise you
  11. #1103
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by jurroid13 View Post
    what?
  12. #1104
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by alclot View Post
    Hi mates,
    Other dash I´m looking for power up. Car is a Ford Transit year 2014.
    Thanks in advance
    did you mange to get power up on this ford transit 2014 see image attached if someone can help
    'If I helped, please click Thanks +Reputation.. !'
  13. #1105
    Mar 2009
    Slovakia
    Hi. I need pinout /GND and +12V/ scooter Peugeot Geopolis 300, 2012 year.
  14. #1106
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by julo45 View Post
    not sure:
    Stecker weiss 20 Pin
    1 Kl. 15
    4 Kl. 30
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16 Kl. 31
    17
    18
    19 Wegsignal
    20
  15. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (6th November, 2018), julo45 (5th November, 2018)
  16. #1107
    alclot's Avatar
    Melee Island
    Hi mates,
    I have AUDI A4 year 1996 with this VDO dash. May I have power up?
    Thanks in advance
  17. #1108
    bidu20's Avatar
    Jun 2016
    Hi mates,
    Thanks in advance
    Stecker blau links
    (26 Pin)
    2 buzzer
    3 Kl. 15
    4 Kl. 15
    5
    6 Kl. 61
    7 Handbremse
    8 ABS
    9 Airbag
    10 CAT Kl. 31
    11 ABS invertiert Bj 97
    12 Airbag invertiert Bj 97
    13 Pariking light rechts
    14 Ignition Switch S
    15 Glocke
    16
    17
    18 Motoröldruck
    19 Standlicht
    20 Kühlmitteltemp.
    21 Blinker rechts
    22 Fernlicht
    23 Geschwindigkeits-
    signal
    24 Bremsflüssigkeit
    25 Bremsklötze
    26 Parking light links
    Stecker gelb rechts
    (26 Pin)
    1 Kl. 58
    2 Kl. 58
    3 Drehzahlsignal
    4
    5 Clock
    6 Geschwindigkeits-signal 1 Ausgang
    7 Geschwindigkeits-
    signal 2
    8 Fahrertür Kontakt
    9 Kl. 30
    10 Kl. 30
    11
    12 Tank Warnung
    13 Blinker links
    14
    15
    16 Sitzgurt Schalter
    17
    18 Kl. 31
    19 Kl. 31
    20 Diagnostic
    21
    22
    23
    24
    25 Tank
    26 Kühlwassertemperatur
  18. The Following User Says Thank You to bidu20 For This Useful Post:
  19. #1109
    Oct 2015
    Hi, I need pinout to connect in bench and kline for this dash from Seat Ibiza 2000y
  20. #1110
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by Perryking View Post
    Stecker - blau
    1 Kl. 15
    2 Blinker rechts
    3
    4
    5
    6 Kl. 31
    7 Kl. 31
    8
    9 Kl. 31
    10
    11
    12
    13
    14 Nebelschlussleuchte
    15
    16
    17 Fernlicht
    18 Blinker links
    19 Kl. 31
    20
    21 Türkontakt
    22 Kühlwasserstand
    23 Kl. 30
    24 Kl. 31
    25
    26
    27
    28
    29 Bremsverschleiss
    30 Kl. 15
    31
    32
    Stecker - grün
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20 Handbremse
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
  21. The Following 4 Users Say Thank You to bidu20 For This Useful Post:
    alclot (7th November, 2018), JotaB (14th December, 2022), Perryking (7th November, 2018), _estima_ (12th February, 2019)
