2012 Honda Pilot pin out plus 93c76 chip location.
alclot (5th December, 2018), MileageAudit5 (24th December, 2020), teekay421 (20th February, 2019), vasa (5th December, 2018)
Has someone power up pins for ISUZU D-MAX 2007 cluster?
and maybe rpm and speedo well :-)
found;
2016-08-05 06.40.32_36.jpg here you go mate
if you think i helped youkindly press REP+THANKS button
any1 have pinout for grand i10 dash 2017 ???
If i was helpful DONT forget the THANKS and REP button
Has someone power pinout for Laguna 1 dash? Please see picture its looks different as usual Laguna dashboard.
this is Laguna 1998
Stecker rot links
(30 Pin)1 2 3 Kühlwassertemperatur 4 5 6 7 8 9 Masse Beleuchtung Kl. 31 10 11 Kl. 15 12 13 14 15 16 Tank 17 18 19 20 21 Kl. 31 22 23 24 Tank 25 Standlicht 26 27 Kl. 30 28 29 30
Stecker grau rechts
(15 Pin)1 Drehzahlsignal 2 Geschwindig-keitssignal 3 4 5 6 Kl. 31 7 8 9 10 11 12 13 14 15
Don't forget the magic button !
AUDI A6 2014 DASH power up pinout please..
_______________ D3-oToprog _________________
ig : vanos_batam
vanos batam (15th December, 2018)
hi
audi 4G
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
alclot (19th December, 2018), shanektm450 (21st December, 2018), Steve182 (13th December, 2019), vanos batam (17th December, 2018)
kawasaki z900 2014 need power pinout
Has someone power up pins for Bmw E82 2009
Press Thanks and Reputation
Aprilia shiver 750
Aprilia mana 800
Aprilia dorsoduro
Thanks if helped
julo45 (23rd December, 2018), karmoranas (3rd April, 2025), nesmark (13th February, 2022), r1yamaha (9th December, 2023), tomo776 (13th March, 2020)
Power up on table yesterday toyota corolla 2003 to 2006 japan cluster 83800-1E730
There are two connectors use with the 40 pins, follow the pins to power up
Pin 1 is right upper corner
Pin 1 Ground(signal)
Pin 2 Ground(powerup)
Pin 4 power (ignition)
Pin 5 power(hot all time)
Pin 32 power(ignition)
