Page 86 of 141 FirstFirst ... 3676818283848586878889909196136 ... LastLast
Results 1,276 to 1,290 of 2114
  1. #1276
    Oct 2015
    Hi, I need power up for this dash from Santana
  2. #1277
    Jan 2018
    Helping others:
    ACURA RDX 2017 DENSO
    PIN 2 - 12 V
    PIN 16 GND
  3. The Following User Says Thank You to llanesluna For This Useful Post:
    alclot (3rd July, 2019)
  4. #1278
    Jan 2018
    Jeep Commander 2007
    Power and CAN if possible please?
    Thanks in advance.
  5. #1279
    Plcautoparts's Avatar
    Mar 2013
    Quote Originally Posted by llanesluna View Post
    Jeep Commander 2007
    Thanks in advance.
    Connector 2 20 pin
    Pins 1, 13, 19 GND
    Pins 2, IGN
    Pin 9 Batt.
    Connector 3 20 pin
    Pin 9 CAN B high
    Pin 10 CAN B Low
    Sent from my SM-N960U using Tapatalk
    A simple thanks would do, If it didn't work at least I tried.
  6. The Following User Says Thank You to Plcautoparts For This Useful Post:
    llanesluna (7th June, 2019)
  7. #1280
    bmwparts's Avatar
    RSA (where men are men and sheep are nervous)
    Good Day All,
    Does anyone have power up for Hyundai H100 or Kia K2700 (They are pickups).
    Kind Regards
    If things seem under control, you are just not going fast enough!!
  8. #1281
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    need wiring diagram on these 2008 ford ranger speedo not working want to test for speed sensor input to cluster if there are signal coming in as speedo needle not moving and mileage not counting up - everything else rev counter fuel gauge etc works
    Quote Originally Posted by jjservice View Post
    Here you go mate...
    Dont 4get thanks button..
    *jjservice*
    'If I helped, please click Thanks +Reputation.. !'
  9. #1282
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by rtbdiagnostic View Post
    Wiring won't help you, it's all sent from the ECM over the Can Bus. Just a good scantool is needed.
  10. The Following User Says Thank You to clusters For This Useful Post:
    rtbdiagnostic (19th June, 2019)
  11. #1283
    May 2015
    My Tool Room
    Procedure for testing without scan tool i.e. manually works 100% on these 07-11 Ford Rangers
    On the instrument cluster press and hold the RESET button, turn the ignition switch to the ignion on position II, and then continue pressing the RESET button (5 seconds) until test is displayed in the odometer. The SELECT/RESET button must be released within three seconds of the odometer test display to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any stored continuous DTCs before proceeding to the next step. Odometer Display Description GAGE= Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster. All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative INSTALL a new instrument cluster. BLUB= Illuminates all micro-controlled indicators and LEDs. Install a new indicator or LED as necessary. R= Returns to normal operation of all micro-controlled indicators and LEDs and displays hexadecimal value for ROM level. If alternating flashes for FAIL and ROM level are displayed, INSTALL a new instrument cluster. EE= Displays the hexadecimal value for EE level . If alternating flashes of FAIL and EE level are displayed replace instrument cluster. DT= Displays hexadecimal coding of final manufacturing test date . DTC = Displays continuous DTC's in hexadecimal format. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step. See index below for description of trouble codes. ENG= Displays the English speed in MPH. Speedometer will indicate present speed within tolerances. Display will show 0 if input in not received. If input is invalid for one second or more, or if speed is 0. M= Displays the metric speed data in kph. Speedometer will indicate present
    speed within tolerances. Display will show 0 if input in not received. If input is invalid for one second or more, or if speed is 0. TAC= Displays the tachometer data received from the PCM via the SCP network within tolerances. Tachometer will indicate present RPM. Display will show 0 if input is no received, if input received is invalid for one second or more, or if engine RPM is 0. FUEL= Displays the code (0-255) for the fuel sender input to the HEC. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. 255= open send +/- 0 232= full stop +/- 0 215= Full mark +/- 10 178= 3/4 mark +/- 8 138= 1/2 mark +/- 7 93= 1/4 mark +/- 5 41= E mark +/- 4 54= Low Fuel (0-59) 0-18= short (0-20 max) OIL= Displays the code (0-250) for the oil pressure switch input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6psi) will display a value between 000 and 176. A low oil pressure or an inoperative engine oil pressure switch (less than 6 psi) will display a value greater than 176. dEG'C= Display of engine temperature in Degrees C input from cylinder head temperature sensor. 49 C= "C" mark 60 C= Normal band start 120 C= Normal band end -40 C= No SCP message for 5 seconds battery voltage Displays the code (0-255) for the battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage. 93-102 6.2-9.1 volts, low voltage 115-124= 8.5-10.7 volts, Normal band star t 215-225= 15.8-18 volts, Norm band end 230-241= 16.9-19.1 volts, high voltage rhEo= Displays the present decimal rheostat dimming input, 0-255 rhi rhS
    rho Not used. CR= Displays the current RUN/START sense input. Display will show -h for high input with the ignition switch in the START position and -L for low input with the ignition switch in the RUN position. PA-PE7= not used. GAGE= Repeats the display cycle To exit the HEC Dealer Test Mode, turn the ignition switch to the OFF position ------------------------------------------------------------------------ NOTE: DTC Codes are not to be used for diagnosing problems. If you believe there is a problem with your car, you should have it scanned with an code reader. DTC Description Common Diagnostic Trouble Codes B1202 9202 Fuel Sender Open Circuit B1204 9204 Fuel Sender Short to Ground B1213 9213 Anti-Theft Number of Programmed Keys is Below Minimum B2103 9232 Antenna Not Connected - Defective Transceiver B1232 A103 Antenna Not Connected - Defective Transceiver B1317 9317 Battery Voltage High B1318 9318 Battery Voltage Low B1342 9342 ECU Is Defective B1356 9356 Ignition Run Circuit Open B1364 9364 Ignition Start Circuit Open B1600 9600 PATS Ignition Key Transponder Signal is Not Received - Damaged Key or Non -PATS Key B1601 9601 PATS Received Incorrect Key-Code from Ignition Key Transponder (Unprogrammed Key) B1602 9602 PATS Received Invalid Format of Key-Code From Ignition Key Transponder (Partial Key Read) B1681 9681 PATS Transceiver Signal is Not Received (Not Connected, Damaged, or Wiring) B2139 A139 PCM ID Does Not Match Between Instrument Cluster and PCM B2141 A141 NVM Configuration Failure (No PCM ID Exchange Between Instrument Cluster and PCM) B2143 A143 NVM Memory Failure C1284 5284 Oil Pressure Switch Failure
  12. #1284
    lucas7117's Avatar
    May 2018
    Windy City
    UPDATE: figured it out: PINS: D13-GND ; D14,D15-12V+
  13. #1285
    May 2015
    My Tool Room
    howzit need power up on this 2005 ford ranger cluster
  14. #1286
    dashradio's Avatar
    Inafield
    Try this...........
  15. The Following 2 Users Say Thank You to dashradio For This Useful Post:
    rtbdiagnostic (30th June, 2019), skens (11th July, 2019)
  16. #1287
    Jan 2018
    Maserati Levante 2017 power up and CAN connection please?
  17. #1288
    UK
    Does anyone have the power up for 2017 Toyota Aygo cluster pls? It has 1 black connector & 1 white connector on rear.
    if this post was usefull
    please press
    the thanks button
  18. #1289
    Newbie chraa47's Avatar
    Apr 2018
    PLS POWER UP FOR RADIO SWIFT SUZUKI NP74L4
  19. #1290
    Feb 2017
  20. The Following User Says Thank You to aGun For This Useful Post:
    dashradio (19th July, 2019)
