Page 82 of 149 FirstFirst ... 3272777879808182838485868792132 ... LastLast
Results 1,216 to 1,230 of 2229
  1. #1216
    Oct 2015
    Quote Originally Posted by bidu20 View Post
    Stecker A
    1 Aussentemperatur Kl. 31
    2 Kühlwasserstand
    3 Kl. 31
    4 Speicherschalter für MFA Reset
    5 Kl. 31
    6 Speicherschalter für MFA Memory
    7 Geschwindigkeits-
    signal
    8 Motoröldruckschalter 1.8 bar
    9 Motoröldruckschalter 0.3 bar
    10 Drehzahl
    11 Kl. 30
    12 Standlicht
    13 Kl. 15
    14
    15 Abruftaste für MFA
    16 Alternator D+ (Kl. 61)
    17 Motoröltemperatur
    18 Handbremse
    19 Aussentemperatur
    20 Vorglühzeit
    21 Tank
    22 Blinker links
    23 Kühlwassertemp.
    24 Blinker rechts
    25 Fernlicht
    26 Tank
    27 Geschwindigkeits-
    signal
    28 Wählbereichsanzeige
    here mate..
    Tried like this but not work... any other pinout?
  2. #1217
    Sep 2009
    right here right now
    Could someone please help with pinout for this bmw k1200s, vdo 6 pin , thanks
    Sent from my E6653 using Tapatalk
  3. #1218
    Oct 2015
    Default Yamaha Tmax 2014
    Hi mates,
    Can I have year 2014 yamaha Tmax dash power up?
    Thanks in advance
  4. #1219
    Oct 2010
    This one also works for Citroen C5 2008-> Dash
    Pin 1 : 12V
    Pin 3 : GND
  5. #1220
    Feb 2010
    i need pinout power Nissan Navara d22 (2003), painel K20061 VK415
    best regards
  6. #1221
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by fcarocha View Post
    best regards
    batt, ign, gnd Is written on the back?!
    Don't forget the magic button !
  7. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (29th March, 2019)
  8. #1222
    Sep 2014
    Hi. Anybody have power up for dash Lexus NX 200?
  9. #1223
    Feb 2018
    Hello i need pinout for dash Opel Insignia 2018 please help
  10. #1224
    Feb 2010
    no have write. last model have write.
  11. #1225
    Mar 2019
    tanks bro good work
  12. #1226
    bidu20's Avatar
    Jun 2016
    send a picture from dash
  13. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (1st April, 2019)
  14. #1227
    bmt_hr's Avatar
    Croatia
    CASE 5130
    Attachment 608723
  15. The Following 2 Users Say Thank You to bmt_hr For This Useful Post:
    alclot (1st April, 2019), skens (8th May, 2019)
  16. #1228
    Jul 2010
    world
    Hello there i need power up pins for Alfa Romeo 166 1999
  17. #1229
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by gsmflasch View Post
    Stecker A - weiss
    1 Blinker links
    2 Blinker rechts
    3 Vorglühanzeige
    4 Nebellampen
    5 ASR defekt
    6 Sicherheitsgurte
    7 Alternator
    8
    9
    10
    11 Einspritzung defekt
    12 Cruise Control
    13 Anlasser Kl. 50
    14 Kl. 30
    15 Kl. 15
    16 Kl. 31
    17 Standlicht
    18 Standlicht
    19 Tank
    20 Tank
    Stecker B - blau
    2 Geschwindigkeits-
    signal
    3
    4 Drehzahl
    5 Geschwindigkeit
    wiederholung
    Ausgang
    6 Geschwindigkeit
    wiederholung
    Ausgang
    7 Geschwindigkeit
    wiederholung
    Ausgang
    8 Geschwindigkeit
    wiederholung
    Ausgang
    9 Tachofreigabe
    Kofferraumdeckel
    Ausgang
    10 max. Temp.
    Kühlflüssigkeit
    Eingang
    11 Innenleuchte Ausgang
    12 Rücksetzung Zeitgeber Innenleuchte Eingang
    13 Kofferraumdeckel offen
    14 Check Türen
    15 Check Türen
    16 Check Türen
    17 Check Türen
    18 Motorölstand
    19 Motorölstand
    20 Heckscheiben-
    heizung
    Stecker C - schwarz
    1 K-Leitung
    2 K-Leitung Kl. 31
    3
    4 Alfa Code
    5 Standlicht
    6 Fernlicht
    7 Beleuchtung Fehler
    8 ABS Fehler
    9 Airbag Fehler
    10 Handbremse /
    Bremsflüssigkeit
    11 Blinker / Anhänger
    12 Bremsverschleiss
    13 Motoröldruck min.
    14
    15 Kühlwassertemp.
    16 Beifahrer Airbag aus Eingang
    17 Tank Ausgang
    18
    19 EBD defekt Eingang
    20
    Stecker D - schwarz
    3 LED auf Tunnel d Ausgang
    4 LED auf Tunnel n Ausgang
    5 LED auf Tunnel r Ausgang
    6 LED auf Tunnel p Ausgang
    7 LED auf Tunnel +/- Ausgang
    8 Tunnel Kl. 31
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20 Automatikgetribe ZF
  18. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (2nd April, 2019), gsmflasch (3rd April, 2019)
  19. #1230
    Feb 2018
    HI,
    Im looking for power up pins for dashboard HONDA CBR1000RR 2006year
