Page 19 of 149 FirstFirst ... 914151617181920212223242969119 ... LastLast
Results 271 to 285 of 2227
  1. #271
    pierre renault
    Guest
    please pinout for Dash Peugeot 207
  2. The Following User Says Thank You to pierre renault For This Useful Post:
    digger75 (15th March, 2016)
  3. #272
    Dec 2009
    Serbia
    It is from Nyo
  4. The Following 3 Users Say Thank You to kizagt For This Useful Post:
    capi (14th June, 2015), digger75 (15th March, 2016), natana (9th August, 2018)
  5. #273
    Rtronics's Avatar
    Dec 2009
    Australia
    Default mini 2002
    Hi, anyone have a powerup for 2002 Mini.
    when i power it up i get lcd power up and temp moves but i dont see kilometers.
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
  6. The Following User Says Thank You to Rtronics For This Useful Post:
  7. #274
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Cool
    Quote Originally Posted by Rtronics View Post
    These is from DIGA manual ,work 100%
  8. The Following 4 Users Say Thank You to cokolo For This Useful Post:
    claudio35 (19th January, 2014), digger75 (15th March, 2016), Rtronics (19th January, 2014), t1tan1 (3rd April, 2014)
  9. #275
    Rtronics's Avatar
    Dec 2009
    Australia
    Quote Originally Posted by cokolo View Post
    still only see temperature ? no kilometers. any trick ? tried pushing top left button and top right button,and together.......
  10. The Following User Says Thank You to Rtronics For This Useful Post:
  11. #276
    Dec 2009
    Prussia
    Do the kms flash up just for a second?
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  12. The Following User Says Thank You to TULGEYWOODMAN For This Useful Post:
  13. #277
    Rtronics's Avatar
    Dec 2009
    Australia
    No, but cause I pulled this out of a bin I just realized its the tacho dial not the speedometer dial. Having said that there was km in dg128 I read. I havnt done a mini before. Hw6 sw16. Don't know if that helps.
    Sent from my iPhone using Forum Runner
  14. The Following User Says Thank You to Rtronics For This Useful Post:
  15. #278
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    For me always work , except if you erased flash from processor .
  16. The Following User Says Thank You to cokolo For This Useful Post:
  17. #279
    honingkoning's Avatar
    Jun 2010
    Dessert
    Does someone have pinout for golf 6 power up and can high/low.
    Wbr Adam.
  18. The Following 2 Users Say Thank You to honingkoning For This Useful Post:
    digger75 (15th March, 2016), Dr Alex (14th April, 2016)
  19. #280
    Dec 2009
    Hi does anyone have power up for renault trafic new one with 93c76 single plug thanks
  20. The Following User Says Thank You to diagtech For This Useful Post:
  21. #281
    Sep 2009
    Does anyone have power up for Yamaha MT01 motorcycle clocks please
    Don't forget to hit thanks button
  22. The Following User Says Thank You to javyb For This Useful Post:
  23. #282
    Feb 2012
    honingkoning I saw it today
    Pin 16 - GND
    Pin 31 + 12v
    Pin 32 + 12v
    Pin 28: Can H
    Pin 29: Can L
  24. The Following 4 Users Say Thank You to kiszony11 For This Useful Post:
    digger75 (15th March, 2016), Dr Alex (14th April, 2016), honingkoning (5th February, 2014), t1tan1 (3rd April, 2014)
  25. #283
    Nov 2009
    Can I see mileage on E90/E91/E92/E87 dashboard????
    Only has 1 plug.
    PIN 9 12V
    PIN 10 GND
    Works gauges returns to initial position, but display dont power up, so I cant see mileage.
    Can I see it?? Or it is imposible in bench without car??
    Thanks!!
  26. The Following User Says Thank You to GolfmkI For This Useful Post:
  27. #284
    neuro's Avatar
    Dec 2010
    UK
    Pictured 61 plate one.
    Power up for late speedo with single plug from Vivaro / Traffic / Primastar with 93C76
  28. The Following 11 Users Say Thank You to neuro For This Useful Post:
    bmwparts (18th May, 2024), capi (14th June, 2015), dashradio (7th February, 2014), diagtech (19th February, 2014), digger75 (15th March, 2016), gameiruz (21st September, 2014), jarripote (17th December, 2015), line44 (19th May, 2019), raf0468 (8th March, 2014), Silver740 (28th October, 2019), t1tan1 (3rd April, 2014)
  29. #285
    cjawahir's Avatar
    Dec 2009
    T&T
    Quote Originally Posted by GolfmkI View Post
    Only has 1 plug.
    PIN 9 12V
    PIN 10 GND
    i too will like to know this , does this need a CANBUS device to switch the cluster on ?
    cj
    Thanks!!
    yes i will also like to know this , does this need a CANBUS device to switch the cluster on ?
    cj
  30. The Following User Says Thank You to cjawahir For This Useful Post:
