Page 72 of 149 FirstFirst ... 2262676869707172737475767782122 ... LastLast
Results 1,066 to 1,080 of 2224
  1. #1066
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by suett View Post
    Hello anyone has pinout for Renault safrane 98 DASH. ...
    Thanks.
    here:
    Stecker - rot
    1 Fernlicht
    2 Nebelschlussleuchte
    3 Fernlicht
    4 Abblendlicht
    5 Nebellampe
    6
    7 Blinker rechts
    8 Blinker links
    9 Kl. 15
    10 Kl 15
    11 Kl. 30
    12 Bordcomputer Taste
    13 Dimmer Beleuchtung
    14 Standlicht
    15 Schalterbeleuchtung
    16 Alternator D+ (Kl. 61)
    17 Kühlwassertemp.
    18 Vorglühlampe
    19 Einspritzung
    20 Automat Störung
    21 Motoröldruck Kl. 31
    22 Kühlwassertemp.
    23 Kl. 31
    24 Motorölstand
    25 Motorölstand
    26 Drehzahl
    27 Durchfluss
    28 Motoröltemp.
    29 Motoröltemp. Kl. 31
    30 Motoröldruck
    Stecker - blau
    1 Kl. 31
    4 Tankreserve Kl. 31
    5 Tank Kl. 31
    6 Tank
    7
    8 Tank min.
    9 Kl. 31
    10 Kl. 31
    11 Sitzheizung
    12
    13
    14
    15
    16
    17
    18
    19
    20 Scheibenwaschwasser
    21 Geschwindigketis-
    signal
    22
    23
    24 Bremsflüssigkeit
    25 Bremsverschleiss
    26 Bremsverschleiss
    27 ABS
    28 Servolenkung
    29 Handbremse
    30 Servicelampe
    Don't forget the magic button !
  2. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (10th October, 2018)
  3. #1067
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    2014_Mitsubishi_Mirage_Instrument_Cluster.jpg hello mates anyone has power up on bench on this MITSUBISHI MIRAGE/G4?
  4. #1068
    Plcautoparts's Avatar
    Mar 2013
    Could you pass picture of the back of circuit board, i believe you can power it up from the back!!
    A simple thanks would do, If it didn't work at least I tried.
  5. #1069
    Sep 2009
    Floridai, usa
    Here are the pins for the Audi TT, i think they where posted in text only already. Hope it helps.
  6. The Following User Says Thank You to djkrugger For This Useful Post:
    alclot (3rd October, 2018)
  7. #1070
    Jan 2018
    2000 Toyota 4Runner - Surf power pinout please.
  8. #1071
    Jul 2016
    USA
    Please help find power up pinoutL, I'm looking for power up pinout for 2006 Volvo VNL 760 Truck.
  9. #1072
    Jul 2016
    USA
  10. #1073
    bidu20's Avatar
    Jun 2016
    Volvo Truck
    Stecker A grün
    (oben rechts, 22 Pin)
    1 Kl. 30
    2 Kl. 31
    3 Kl. 15
    4 Bedienhebel,
    Display-Schalter "Enter"
    Kl. 30
    5 Bedienhebel, Display-Schalter "Escape" Kl. 30
    6 Bedienhebel, Display-Schalter "Aufwärts" Kl. 30
    7 Bedienhebel,
    Display-Schalter "Abwärts"
    Kl. 30
    8 nicht belegt
    9 Kl. 30
    10 CAN 3 A 0 - 5V
    11 Schalter Standheizung gilt nicht für alle Ausführungen!
    Kl. 30
    12 Massereferenz Geber
    13 nicht belegt
    14 nicht belegt
    15 CAN 1 A 3 - 5V
    16 CAN 1 B 0 - 3V
    17
    18
    19 Standheizung, Aktivierung gilt nicht für alle Ausführungen!
    Kl. 30
    20 nicht belegt
    21 Warnblinker Kl. 30
    22 CAN 3 B 0 - 5V
    Stecker B grün
    (mitte rechts, 30 Pin )
    1 Kl. 31
    2 nicht belegt
    3 Tank 0 - 5V
    4 nicht belegt
    5 nicht belegt
    6 nicht belegt
    7 nicht belegt
    8 Batterieladung, Geber gilt nicht für alle Ausführungen!
    0,5 - 4,5V
    9 Aussentemperatur 0 - 5V
    10 nicht belegt
    11 nicht belegt
    12 Öltemperatur Getriebe gilt nicht für alle Ausführungen!
    0 - 5V
    13 Bremsdruckgeber, vorderer Kreis 0,5 - 4,5V
    14 Bremsdruckgeber,
    hinterer Kreis
    0,5 - 4,5V
    15 nicht belegt
    16 nicht belegt
    17 nicht belegt
    18 nicht belegt
    19 nicht belegt
    20 Versorgungsspannung
    4,5 - 5,5V
    21 Versorgungsspannung
    Bremsdruckgeber,
    hinterer Kreis
    4,5 - 5,5V
    22 nicht belegt
    23 Versorgungsspannung Radiostellung gilt nicht für alle Ausführungen!
    24 nicht belegt
    25 nicht belegt
    26 nicht belegt
    27 Standlicht Kl. 30
    28 Schalter Schleppachsenheber Kl. 31
    29 nicht belegt
    30 Stromversorgung Batterieladung, Geber gilt nicht für alle Ausführungen!
    4,5 - 5,5V
    Stecker C blau links
    (Pin 1 - 15)
    1 nicht belegt
    2 Anhänger ABS, Status Kl. 30 (Lampe inaktiv)
    3 Fahrzeug ABS, Status Kl. 30
    (Lampe
    inaktiv)
    4 Antrieb Vorderräder Kl. 30
    (Lampe inaktiv)
    5
    6 Ausgleichssperre, vorne (4x4/6x6)
    Ausgleichssperre, Rad (6x4/8x4)
    2. angetriebene Achse hinten
    Kl. 30
    (Lampe
    inaktiv)
    7 Alternator Kl. 30
    8 Schleppachsenheber Kl. 30
    (Schlepp-achsen-heber am Anschlag)
    9 Kippverriegelung, Fahrerhaus Kl. 30
    (Fahrerhaus gekippt)
    10 Ausgleichssperre,
    Achsen
    Kl. 30
    (Schalter aktiv)
    11 Ausgleichssperre, Rad (6x4/8x4)
    1. Angetriebene Achse hinten (6x6)
    1./2. angetriebene Achse hinten
    Kl. 31(Ausgleichs-sperre aktiv)
    12 Vorheizen, Motor Kl. 30 (Startvor-heizung aktiv)
    13 Schleppachsenheber Anhänger
    14
    15
    (Pin 16 - 30)
    16 Servolenkung Kl. 31
    (Funktion aktiv)
    17 Gepäckraumklappe, Status Kl. 31
    (Klappe offen)
    18 Getriebe, "Split langsam" Kl. 31
    ("Split langsam" aktiv)
    19 Gurtwarner Kl. 31
    (Gurt nicht angelegt)
    20 nicht belegt
    21 nicht belegt
    22 Lenkradschalter gilt nicht für alle Ausführungen!
    7 - 9V
    23 nicht belegt
    24 nicht belegt
    25 Versorgungsspannung
    Lenkradschalter
    7 - 14V
    26 nicht belegt
    27 Aufbau Information/Warnung Kl. 31
    (Information aktiv)
    28 Anhänger ohne ABS Kl. 31
    (Funktion aktiv)
    29 Scheibenwasserstand Kl. 31
    (Stand zu niedrig)
    30 Masseanschluss Lenkradschalter gilt nicht für alle Ausführungen!
    Bemerkung
    Tank
    1. Strich = 228Ω
    2. Strich = 158Ω
    3. Strich = 103Ω
    4. Strich = 64Ω
    5. Strich = 38Ω
    Bremsdruck
    1. Strich = 106kΩ
    2. Strich = 84kΩ
    3. Strich = 55kΩ
    Mitte = 50kΩ
    4. Strich = 36kΩ
    5. Strich = 22.4kΩ
    6. Strich = 17kΩ
    Getriebe-Öltemperatur
    20°C = 0.8 - 1.1kΩ
    70°C = 150 - 220Ω
    80°C = 110 - 160Ω
    90°C = 80 - 120Ω
    100°C = 60 - 90Ω
    110°C = 50 - 70Ω
    120°C = 35 - 55Ω
    130°C = 30 - 45Ω
    140°C = 20 - 35Ω
    150°C = 18 - 25Ω
    Aussentemperatur
    -40°C = 8.6 - 12.9kΩ
    -20°C = 2.9 - 4.4kΩ
    -10°C = 1.8 - 2.7kΩ
    -4°C = 1.3 - 2.0kΩ
    0°C = 1.1 - 1.7kΩ
    4°C = 0.9 - 1.4kΩ
    10°C = 0.7 - 1.1kΩ
    20°C = 0.5 - 0.7kΩ
    40°C = 0.2 - 0.4kΩ
  11. The Following 3 Users Say Thank You to bidu20 For This Useful Post:
    alclot (3rd October, 2018), dustooff (20th May, 2019), vasa (30th September, 2018)
  12. #1074
    Apr 2010
    Looking for Jeep grand cherokee 2007 dashboard pinout including CAN
    Thnaks !!
  13. #1075
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by stammba View Post
    Thnaks !!
    do you have a picture or e partnumber?
  14. #1076
    Apr 2010
    P/N CR-0034-120-K0-CC
    Quote Originally Posted by bidu20 View Post
  15. #1077
    Jan 2018
    Did not work on a 2013
    Just to let you know.
    Quote Originally Posted by lwood View Post
    2012-2014 Nissan Versa, Power Up
    93C86
  16. #1078
    May 2018
    hi, anyone have power up for bmw F models?
  17. #1079
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by yeager2 View Post
    Stecker
    1 Kl. 30
    2 Kl. 30
    3 N.C.
    4 Temperatur Aussensensor
    5 Temperatur Aussensensor
    6 CAN High
    7 Kl. 31
    8 Kl. 31
    9 N.C.
    10 Spannungsversorgung Head-Up Display
    11 Kl. 15
    12 CAN Low
    try this
  18. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (3rd October, 2018), skens (3rd October, 2018)
  19. #1080
    letalcrudo's Avatar
    Nov 2015
    Canada
    NISSAN TERRANO 2012. with 93c66 eeprom inside
    (maybe it was posted before. anyway hope it helps someone else)
  20. The Following User Says Thank You to letalcrudo For This Useful Post:
    jomberykaso (12th August, 2022)
