Page 113 of 149 FirstFirst ... 1363103108109110111112113114115116117118123 ... LastLast
Results 1,681 to 1,695 of 2229
  1. #1681
    Jan 2014
    Default Piaggio Beverly 125 - 250
    Hello , can somebody help with pinout for Power up - Piaggio Beverly 125 - 250 cluster. It is 16pin connector. Thanks
    If my post was helpful please push the Thanks button and Rep button.
  2. #1682
    Aug 2013
    Can someone share powerup for this DMAX?
  3. #1683
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by toastedsiopao View Post
    Which dmax put a picture
  4. #1684
    Aug 2013
    DMAX 2008 model
  5. #1685
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    DMAX 2008 model
    Pin 1 is ground and pin 8 is +12VOLTS .
    notice the numbers on the 16 pin connector where its solder to the pcb
    Always better to post pictures when possible
  6. #1686
    Aug 2013
    It is not working that way..
  7. #1687
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    DMAX 2008 model
    better you take a photo of dash....
    here are the 3 versions of DMAX
    if you think i helped youkindly press REP+THANKS button
  8. The Following User Says Thank You to jjservice For This Useful Post:
    toastedsiopao (2nd May, 2021)
  9. #1688
    McDowell's Avatar
    Feb 2019
    Zamunda
    Peugeot 3008 can power up
    Hello mates,
    Please do you know how to power up this dashboard? Do I need CAN signal? I would like to know how to connect thank you very much.
  10. #1689
    Top Poster MasterCodein's Avatar
    Oct 2018
    Jupiter
    2005-2008 Ford Mustang pinout
    Small contributions to the post
    Positive 3, 25, 26
    Ground 2
    Sent from my Pixel 2 XL using Tapatalk
  11. #1690
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Can anyone share aprilia rs50 2006 digitek cluster power up?
    Plug is 20 pin.
    Renault ECU tool / IO terminal / A.S.W
  12. #1691
    sv2hqx's Avatar
    Jun 2014
    Default aprilia
    Same like this
  13. The Following User Says Thank You to sv2hqx For This Useful Post:
    drugowaz (5th May, 2021)
  14. #1692
    drugowaz's Avatar
    Mar 2015
    Lithuania
  15. #1693
    Liteace's Avatar
    Mar 2009
    On a rock
    I need to power Rav4 cluster on bench. does anyone have any connection info
  16. #1694
    dashradio's Avatar
    Nov 2009
    Inafield
    Quote Originally Posted by Liteace View Post
    Not my picture, thanks to original poster
  17. #1695
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by dashradio View Post
    Thanks,,, but thats a different and cant risk it
