danocar (23rd February, 2025), dashradio (2nd March, 2025), rtbdiagnostic (28th February, 2025), skens (24th February, 2025)
Hi, can you help me in light the cluster for Toyota Rav 4 2014? I tried +ill and -ill, but it does not illuminate (as in turning the light ON). I have the cluster on the bench, powering it up works, but I want to have also illuminated.
Thanks a lot!
Hello, can anyone help for power supply Iveco Daily 2001. Picture attached. After ignition only 4 lamps work, nothning else.
Thank you
hi
green
pin17,19 +12
pin1 massa
redards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
dashradio (20th March, 2025)
HI, if it possible dash power up toyota avalon 93c56
dashradio (23rd March, 2025), Nightdriver (22nd March, 2025)
Anyone have pinout for 2014 audi a4 or s4 8K0 920983 single grey connector MM dash. I believe it need can for wake up but still needs ground and vcc.
Here.....
AudiS4 (27th March, 2025)
Anyone have pinout for 2021 vw passat dash Part number 561 920 981G?
Hi @RTronics , from another Aussie.
hi anyone have powerup for test in bench
honda africa twin crf1000 2016
silvarog3r (17th April, 2025), tanon (16th April, 2025)
HELLO GUYS,
Maybe anyone could help me with EEPROM pinouts for Suzuki gsxs 750 2018? also would be great 12v and ground to test it after changes.suzuki gsxs 2018.jpgsuzuki gsxs 2018 1.jpgsuzuki gsxs 2018 2.jpgsuzuki gsxs 2018 3.jpgsuzuki gsxs 2018 4.jpg
