Does anyone have power up for for DASH, Kawasaki GTR 1400 2012
Best regards
PRESS THANK + REPUTATION
HONDA LEGEND (KB1/2)3.5 V6 CAT POWER UP
Thanks a lot in advance
Hello, dose any one can guide me how do I power up the cluster, which is the positive and negative, thanks you,
Toyota Corolla 1.4,
Cluster Seimen Vdo, AG
Here......
dustooff (3rd February, 2021), mcd76 (12th August, 2020), rtbdiagnostic (10th August, 2020), skens (6th August, 2020), stzmotors (7th August, 2020)
Hi I need power up connection for ford ranger 2013 t6 with 24c16 chip on bench
Cheers
Shane
shanektm450 (17th August, 2020)
Hi thanks I do understand I have a bcm on bench just need power up of the cluster then I can share working solution for mileage on bench
Cheers
Shane
rtbdiagnostic (17th August, 2020)
Ok got it sorted :
pin 18 - ign
pin 17 - battery
pin 11 - negative
pin 6 - can to obd plug 3
pin 7 - can to obd plug 11
If you got BCM on bench then you need to connect pin 6 and 7 to bcm and splice in to can to obd plug , I manged to do mileage on bench with cluster only , to test to see mileage is to unplug cluster and plug back in again with out turning on ign then you see mileage
Cheers
Shane
dustooff (3rd February, 2021), MileageAudit5 (4th January, 2023), rtbdiagnostic (20th August, 2020), Tyson500 (11th November, 2021)
HI.
Any have power up for this yamaha n-max 2016?
Thanks.
julo45 (28th August, 2020)
2018 KIA sportage c/w 25c160
need to check mileage on bench
2018 kia sportage with 25c160 eep .
1 black 40pin connector
can anyone help with power ups ?
please add rep & thanks if my post was helpful
popov (8th June, 2022)
Anybody can assist with power up on bench for this 2017 Isuzu DMax with RH66 - 93c66 chip it has a black connector
'If I helped, please click Thanks +Reputation.. !'
