Results 1 to 15 of 15
    Jun 2009
    Default tacho universal 2008
    i have bought one but i can not read from punto 2000 processor 908 .
    also after 2 tries it stuck working and do nothing.
    after a while it start smoking.
    i get out the lcd and it was burning.
    if one wants to order a blue one he can chose from ebay just to look in datasheet to be 128x64 with cs1 cs2.
    can someone suggest a clone tachometer that is working ok ?
    i do not want to do it professional but i would like to do cars with 908 and 9s12 processors
    Apr 2011
    I think there is some different types of displayes but Im not 100% sure. Are you sure you have right power supply? How many ampere IN?
    Jun 2009
    i have connected to 12.2v and 1 ampere stabilized .
    its not from power supply.
    i never manage to read 912 and 908 processor.
    always problems
    it read only 93c46 and memories like them
    BigJ's Avatar
    "after a while it start smoking."
    next thing you know:
    and then:
    and
    Damn Tacho Universal's!!
    Keep them away from your daughters!!!
    (Sorry, couldn't resist that!)
    PRESS THANKS AND ADD_REP JUST FOR THE HELL OF IT..... PLEASE.....THANK YOU!
    BigJ's Avatar
    Quote Originally Posted by gadroulll View Post
    Seriously, the blue screen ones seem to have a few issues with the displays themselves (in my experience). Pixels vanish, text gets jumbled up etc.
    My 3 year old, very well used Tacho Universal recently finally died on me, and it's replacment just doesn't seem to work as well. All the time using the TU, i found no hassles with serial eeproms (24cxx, 93cxx, 950xx.) Even very few issues with M35080. It did pretty much everything they claimed it could do. Except:
    NEC chips: Never once worked. 908 etc: Sometimes ok, sometimes nothing. 9S12: Did not work in the beginning but a new replacment dongle and no problems after that. I bought all my original Tacho Universal stuff (repair kits, replacment cables, dongles, etc) from FJE Tech every time but they have long since dissapeared off the web. Your next best bet would be ecu tool I suppose.
    Moving on though, you should look at getting something like a Digimaster 2, then together with a Tacho Universal, you are pretty much covered.
    J
    Apr 2011
    Be aware... I read lot of negative about ecu tools these days.
    I mean the power supply maby did the chimney problem... I have one T U, works like a charm and Ive done like 150 cars with it. only problem is "sync problem" but its easy to solve with the repair kit just a littlebit annoying when it happens on a OBD job at some garage 9000 miles away from your home..
    BigJ's Avatar
    Quote Originally Posted by Dumper View Post
    Here's a trick with the sync problem:
    Take the 24c02 eeprom's from old sd ram cards from old pc's.
    Keep them with your TU.
    When Sync error pops up, just remove the old 24c02 from the TU's CPU board, and solder the sd ram's 24c02 in it's place.
    You don't need to program them or nothing. They work as is. Just like that.
    No need to spend anything on repair kit.
    Jun 2009
    the tu cpu board programs the memory?
    does anyone where to buy repair working kit for my tu?
    Apr 2011
    You chinese dealer have this
    ...where was Columbus
    Quote Originally Posted by BigJ View Post
    Hi!
    I met with Sync ???? problem. Can you explain in detailed please. I need remove the old 24c02 then put new in its place, right? Can I use 24c02 from old SD RAM PC's or just from elsewhere? The 24c02 should be cleard (with FF) or what? Please explain me more datailed. Thanks in advance
    miha99's Avatar
    EU
    Rather buy Willemm programmer for 30usd and use this files from DK.I solve sync problem on 10 unitacho and always In the first attempt!
    Quote Originally Posted by miha99 View Post
    Thanks. I unziped your file but I really can not open the file inside. What the program you use to see this file?
  13. #13
    miha99's Avatar
    EU
    There is nothing to open, you need to write this dumps to an eeprom and both flashs and the cheapest solution is willemm programmer with plcc adapter on board.
  14. #14
    Hey, my friend, It's to much for dump size(616,624). That's why I asked you about file format. Please check it again. Thanks
  15. #15
    Quote Originally Posted by Air View Post
    OK, I've got it. Sorry for that. Never mind. Thanks
