Hi! I found pin out of OBD-2 to Benz38pin cable:
OBD-2 ------------------------Benz 38 pins connector
4+5 ---- 1 (Signal GND)
7 ----15(K-line)
16 ----3(Power)
7 ----15(K-line)
16 ----3(Power)
I checked some connections and pin numbers for the cable that came bundled with Passthru j2534 25 pins to OBD and made the table of connections:
25 pins connector---------------OBD connector
1----------------------------------8
4------------------------------------
&--5
5------------------------------------
6----------------------------------6
7----------------------------------2
9----------------------------------16
10---------------------------------15
11---------------------------------14
12---------------------------------13
13---------------------------------12
14---------------------------------1
15---------------------------------10
16---------------------------------9
24---------------------------------9
The fact that the pin number 7 OBD connector is not used in this cable.
The problem is this: under what number in MB 38 pin connector is K-line?
As far as I know L-line in the OBD at number 15.
I found Mercedes 38 pin diagnostic connector pinout this:Mercedes 38 pin diagnostic connector pinout
But the number of K-line is not listed.
what's this car ?
Mercedes use a lot of pins for k-line, it depends on the ecu you want to scan.
pin 1 --- ground
pin 3 --- +12v
pin 4,5,6...36 --- k-line for engine, abs, srs....(look at the pinout you already posted)
pin 24,25,27,29,35,37,38 are not used
so you need to switch k-line (pin7 from 16-pin obd connector) to the needed pin from 38-pin connector.
I don't know if its the same with passthru.
Thanx! The car is Mercedes-Benz w202 C230 Kompressor 1998y
I use Actia Passthru XS for connect to this car.
Actia Passthru XS pinout this:
From my understanding you need following wiring:
Multidiag 25-pin ---- MB 38-pin
16 or 24 ---- 3
4 or 5 or 25 ---- 1
1 ---- 4 or 5 or 6...36 (24,25,27,29,35,37,38 are not used)
If your 25pin to 16pin passthru cable is correct (i don't think so since obd pin 7 is missing, should be connected to pin 1) you can use manual multiplexer (38 pin breakout box) to manually switch pin 7 to k-line of 38pin connector)
PassThru 25pin--------to---------OBD
pin 7------------------------------2
This is connection of 25pin toOBD cable:
25pin-------------------OBD
1-----------------------8
7-----------------------2
