Results 1 to 8 of 8
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    Default mb star some help required please
    hi guys ive been looking and reading around just confused a little ive got everything loaded and working. ive verified my mb star online etc and it connects to the car (e212)2010 im doing the problem im having is special functions and adaption as im trying to code in a new abs module but it asks me to go online or offline if i select offline it asks for a password ( not in keygen ive got with software) if i try go online i get user name and password were entered too late or incorrect network settings configured in sdnetcontrol
    where are the settings for sdnetcontrol? or do i need to add a key or something ?
    DVD-ROM Release: R2.0, V 03/2011, (2011-02-10)
    Language EN
    Xentry Diagnostics-program V 9.1.6, (2010-12-21)
    Xentry Diagnostics-data 03/2011, (2011-02-04)
    DAS-program V 6.6.0.0, 2010-07-30
    DAS-data 03/2011, (2011-02-10)
    HHTwin passenger car V 19.10.26, (2009-09-11) EN
    HHTwin trucks V 6.96, (2009-10-21) EN
    Mar 2008
    ive managed to get into sdnetcontrol settings and switched it on on start up too but still wont connect is there a keygen for the offline password or do you have to go online?
    For the on-line connection you need an account from MB. Most likely you can forget that option.
    For the W212 (I assume you mean W/S212) you don't have much more options other than doing on-line programming and SCN coding.
    I nead to.
    Mar 2008
    is there a keygen or a way for the offline password procedure?
    Quote Originally Posted by JIMMYQ View Post
    you can install Prototyp models and try to mess around but be carefull
    Mar 2008
    i can communicate with the car its not a problem just need access to module programming ???
    Mar 2008
    under adaptions i get this
    Commissioning can be performed online or offline.
    The online process is always recommended.
    Enabling the offline procedure can be carried out via button 'Offline'.
    Online (networked Star Diagnosis unit)
    if i select offline it asks for a password???/
