Results 1 to 15 of 15
Thread: Pc shuts down
    Feb 2010
    West Mids.
    Default Pc shuts down
    I know this is a bit bear but I don't have the box in front of me.
    It's an asrock motherboard , with an AMD processor , don't know about ram or graphic's ( think it might be onboard )
    My dad's having a bit of trouble with his pc , it was working ok for quite a while although it did seem slow , now it's started to shut down after 10 - 15 mins. It can be when working either online or offline.
    He's swapped the psu for a new one and I've got him to look at the cpu fan to see what thats doing ( haven't heard back yet ).
    Just wondering if anyone could point me in the right dirrection ?
    Thanks , Adam
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Does it Blue Screen or just turn off and wont turn back on for a few mins.
    A Blue Screen (BSOD) is usually caused by a hardware issue, ie ram faults.
    If it just turns off then could be a over heating issue
    Feb 2010
    West Mids.
    Bit of an update
    Found out it's got an athlon 64 dual core cpu with 2gb ram , and it just cuts out , no blue screen
    The power unit was swapped from a 300w to 500w with no difference but after watching while it was running it seems the wires were stopping the cpu fan ( after the swap ) since moveing them iy seems to be running ok again - but I'm not convinced that was the problem originally.
    I've installed hwmonitor and the temps seem to be going from about 45 to 70 c . I found on one site that the temps for the athlon 64 should be about 65 - 70 so I guess it's ok for now.
    Short of just keeping an eye on it can anyone recomend anything else ?
    Thanks , Adam
    DK Veteran jetdede's Avatar
    Nov 2010
    under carter
    if it's happen cause of temperature so you must add fan or may be room temperature more cold..
    try to see option at BIOS abut the temperature limit monitor to shut down motherboard...if like older posting that range between 45 - 70 C and after we added fan or make cold room still not working try to change the limit value...increase it or make it disabled (not recommended)
    Sep 2008
    silly question how dusty is it? a good coating of dust will make things run hotter,even around fan and vents.
    Feb 2010
    West Mids.
    Yea , there was dust on the fans which has been cleaned. He's got 4 fans on it - there's the one on the power , one on the cpu , one at the front of the box , and one on the back so I would have thought it should be ok.
    Guess we'l just have to keep an eye on it for now and see what happens.
    Thanks , Adam
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    make sure the cpu fan is ptoperly connected to the mb that the most common cause of shut down push firmly on the catches until they click not too firmly and go diagonally so as not to put pressure on the mb
    cunny's Avatar
    Jan 2009
    The Shoutbox
    More commonly its a build up of sh1te like dust. These things attract dust. Best thing to do i find is, get a can of air from asda (?3) and take the pc in the garden, pop the case and blow all the sh1te out.
    It can build up quite quickly also, so a regular check of the case will help, you can usually tell when fans are running more than they used to as it gets niosey
    Meat-Head's Avatar
    Had one where it did the same, just stopped dead.
    Apparantly it was full of brick dust, no need to ask questions why.
    Sep 2011
    if it's a heating problem, u can take everest or speedfan software to check temps. Then check out wich one is getting hot, and act on in. Normally it will be or the cpu or graphic card.
  11. #11
    Jul 2011
    Branch Office
    Quote Originally Posted by rabujas View Post
    more software that not to important will increase resource...it will make heat up....just add fan like jetdede said. it's enough...it will better if use in cold room too
  12. #12
    Jun 2008
    Check CPU settings. This could also heat up your PC. Is CPU seated right? Friend of mine put CPU in ok but cooling fan wasn't pushed in right.
    Also is there a fan for any other chip on board? My motherboard has one for a controller. This slowed and it kept turning off. Replaced fan now ok. This also could happen to any of your extra fans.
  13. #13
    Feb 2010
    West Mids.
    Thanks for the reply's , We've got it sorted ( as in it hasn't done it since ) took the cpu and fan off the mb cleaned everything , new 'grease'. We're useing CUPID HWmonitor to keep a check of it.
    Thanks , Adam
  14. #14
    Sep 2011
    Quote Originally Posted by cresad67 View Post
    Thanks , Adam
    every six months get vac on the job..sorted............
  15. #15
    Jul 2011
    Branch Office
    Quote Originally Posted by ultraplex View Post
    if you can make it every 3 months that will be better....dust is so fast even we use pc at cold room with ac
