hi , never ried this befiore sure it can be done ..i would like to acess ubuntu server . over net . at a different location outside the lan ..
has anyone got or use this ,maybe help me ..
many thanks![]()
many thanks![]()
dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
forward whatever port on whatever emulator you use for info on your router to your server, then you can access it from outside your network
be sure to password protect it![]()
it's simply port forwarding you have to do
on router
port 21 for ftp
port 22 for ssh
port 23 for telnet
for example if you are using CCcam, you can edit your CCcam.cfg either way
also dont forget to allow incoming connections to your server
Example:
to access your CCcam info default port from outside your lan
forward port 16001 on your router to your server
to connect to it:
and you will get a login box for username and password so be sure to change the default username/password in CCcam.cfgCode:your.dns.address:16001
maybe this thread shoud be moved to the pc/network section as its not cs or satellite related![]()
cheers i ready to give ago i hvae oscam /cccam..
yes i have a good user pass in cccam cfg..has everyone got to use these ports say i would like to add a f line m8. or a reeboot of server . m8 .what port will give me ubuntu desktop toacess the cfg etc ..as i have secure own made port at he moment m8..many thanks![]()
you could use Teamviewer to access ubuntu from another location, just set it up to allow you only to connect and set a good password
TeamViewer - Free Remote Access and Remote Desktop Sharing over the Internet
or you could open port 22 and use putty to ssh to it
PuTTY: a free telnet/ssh client
and to edit your CCcam.cfg from ssh log in as root and enter this command
and here is a bit of info on using the vi editorCode:vi /var/etc/CCcam.cfg
have a read and try it, quite simple to do really
vi editor Quick Reference
cheers m8 very help ful thanks
one last quwestion please sir .as you can read i aint that good on pc s..
anyway say i open port 21 or 22 .. on router ..does this have to be linked with the same static ip as the ubuntu server m8 ..if you know what i mean ,
cause the port is very secure i was thinking ..do i just open a port and lable it say ssh of ftp ..on router as i application share labeled normally before opening ports i think its that way ..
many many thanks for help .
i would prob use just for checking and adding m8 ..thanks
