Hybrid View
    Default openbox s10 set up for mulisat
    i have now just about set my s10 up for multi sats and removed some channels not needed, is there a way of backing up all the system and when a new firmware comes out just back it up after installing new firmware.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    dump it to usb and save it on ya comp
    Jun 2011
    Bolton, Lancs.
    go to dump to usb, select misc. then dump ya prog. mgcamd sea lions
    Default s10 multi setup
    thanks for the info, so does the prog file cover all changes i have made to sat list and transponder list and channeol list and sat positions, and afteer putting new firmware just add back the old prog file.
    Default s10 recording problem
    when i conecct a pen drive to the s10 and press record it only reciords for about 2 hours at a time can this be increased.and when i put the pen drive in the computer it splits a single recording in to 2 ts files is the pb mode on the box any different.
    Feb 2012
    Quote Originally Posted by ellesmere11 View Post
    I don't know much about sats but this sounds like you need to use bigger capacity pen drive. answer to the other part od question sorry....
