Results 1 to 7 of 7
Hybrid View
    Talking Set up new starview 4
    Hi just got the starview 4 super USB. Inside the box it gave information
    to download onto usb from TheBocSuperUSB_V1.02_betaBIN
    I have done this got the free chanel but all other chanels said downloading data and just stuck at that for hours, Help how can I get further on,
    sorry if its a stupid question but brand new to anything technical, it took me
    half an hour to post this thanks Linda
    hi you need to download 1.07. Go in to downloads you will find it there then put it on to a usb stick and load it onto your SV4
    Talking
    Thank you so much I'll try this and let you know
    Linda
    V.I.P. Member dell_xps's Avatar
    To view the $ channels, press menu on your remote, then 1570 on the remote, you will now see a secret menu, move it down to EMU it will be off, select it and turn it on, exit back to $ky sports 1 and let it update.
    1.2 is older firmware you have there, as the above poster pointed out,download 1.7 put it on your memory stick, put it in the starview, go into the menu select hard drive and flash it with the latest firmware.
    HTH
    DK Veteran bigfella's Avatar
    mick's arse in america
    linda the emu is also known as the keycode on the usb so if u select this turn it on and then press default.exit to sly sports let it update ..you shud be ok ..hope this helps ...bigfella
    Default crack
    whats the crack then
    Member chunder's Avatar
    Nov 2008
    the crack is ninety.
    yourself?
