Results 1 to 15 of 24
    makura's Avatar
    Default SPINTER IMMO MCU READ
    Hi guys
    I have here a MB SPRINTER immo box with mc68hc08az34a with mask 4L52H and i want to read it with my xprog-m but this mask is not on the list,if i try using mask 0J66D it reads but the data come as AD AD AD right through the whole file.
    Has any one faced this problem before?is it in my wiring of i need to read it as something else?
    makura's Avatar
    By the way its a 2002 412D
    Bulgaria
    skip securiti !
    B.R.
    makura's Avatar
    Quote Originally Posted by icogsm View Post
    skip securiti !
    B.R.
    What do you mean?
    If its a question the answer is yes it does pass security and reads but all get is rubbish data.
    joubliss's Avatar
    Far away
    Select MC68HC08AZ32 and Skip Sec.
    makura's Avatar
    Quote Originally Posted by joubliss View Post
    ok one minute..
    makura's Avatar
    Ok,i have selected MC68HC08AZ32,how do i skip security?when try reading it says communication error(1)
    joubliss's Avatar
    Far away
    Select : Device - Skip Sec
    Essex
    make sure you have entered security bytes in enviroment settings
    F1 6A FA 04 - E4 DA FA 04
  10. The Following User Says Thank You to squirrelbandy For This Useful Post:
    timos (15th November, 2015)
  11. #10
    makura's Avatar
    Quote Originally Posted by squirrelbandy View Post
    put in the security bytes,and now i get device is silent error.i am using xprog-m and i dont see the option to skip security
  12. #11
    makura's Avatar
    Update''''''
    Device read,selected MC68HC08AZ32(0J66D) and added the security bytes F1 6A FA 04 - E4 DA FA 04(thanks to squirrelbandy) and it read just fine.
  13. The Following User Says Thank You to makura For This Useful Post:
    DOUGLASDL (28th June, 2017)
  14. #12
    Essex
    glad to hear you read successful
  15. #13
    makura's Avatar
    Now that the chip is read, i cant get the key logic right any one help?
  16. #14
    Mar 2009
    Quote Originally Posted by makura View Post
    your keys.pass pm
    regards
  17. #15
    makura's Avatar
    Quote Originally Posted by HONDA C View Post
    your keys.pass pm
    regards
    So what tool did you use?AD900?on the MB sprinter,vito "START ERROR" V1.3 software it says key 1=788A2FC576 and key 2=9C586A9AFB
    So which one is right here,the car is a bit far away so driving all the way with the wrongly coded key would be a waste.
