contact in privat
I need a working solutions dpf off for this tipe , i already try some variants, even i pay some guys for file off but no succes. In dash glow plug lamp flash, dpf lamp on even with engine off. in atash archive is flash dump, eprom dump ( read with bdm), log with dtc, some information about sw and hw ecu. I need file pdf off and no dtc
Thanks a lot for any help
Last edited by elephantul; 7th October, 2011 at 11:32 AM. Reason: add more information
contact in privat
DPF OFF CRAF
scancar you solution not work, your flash file is not same sw like my file, car not cranck, thanks anyway
Checksum Incorrect
every time i calc checks with bdm, car start only with original sw
contact in privat
Is your file the ori, CS not ok in your posted file.
Here a dpf off file, with CS ok
I have send elephantul the pw
Other people they can do it, do this for money, and elephantul have payed one time for it, and it does not work
I have spend a lot of time for search this solution !!
When you have a problem with DPF and i can help, i help also you.
PS: My english is not so good that i can write here what i want say
sazimam11 (26th June, 2020)
Some people do this job perfectly with this Ecu, @Elephantul don't take the good person for this and this is a bad thing.
Your seller give your money back ?
In local tuner the price is 100 to 150 euros maximum.
Best regards
Original Kwp2000+ and other...
No stress for all !
this forum is not a site where you can find customers .. The workshop is suitable for the site to charge customers need a forum to help users and exchange tips and files to learn how ... Then do as you like .. I put the password and the advice I give you free if you take my money and put the files with the wrong password, this is my opinion
Greetings all
