Page 1 of 4 1234 LastLast
Results 1 to 15 of 63
Hybrid View
    Jun 2011
    Default XENTRY 07_2011 No Password in Special Function (FIX) UPDATE
    With the executable that I have created and enclosure, there is eliminated the need to introduce passwords for the special adjustments, only to pulsate F2 until the corresponding menu appears.( It is necessary to touch 2 times F2 with screens in white)
    It works in all the versions 2011, I have not proved it in previous versions.
    Update: Now also for vans, to apply tr?s the previous one, both are necessary in order that it works in vans.
  2. The Following 16 Users Say Thank You to gcs190 For This Useful Post:
    arti1 (19th October, 2015), bearheroes (20th January, 2016), Carsoft2003 (19th March, 2014), datapage (19th January, 2016), DILIAN_1 (5th February, 2023), DSAuto (14th October, 2016), dzmitry (11th July, 2019), goldbird (11th May, 2014), jakesman (16th June, 2015), junho2696 (22nd May, 2024), lake77 (3rd June, 2014), Milicija (9th January, 2017), Plutoe (14th January, 2014), shawn03 (22nd March, 2014), Smiley75 (29th August, 2013), tomejuss (24th March, 2014)
  3. #2
    Top Poster GSI2's Avatar
    Feb 2009
    moon
    Quote Originally Posted by gcs190 View Post
    Only this one proved in Das/Xentry 07.2011
    Can you include Xentry 7-2011 in topic name?
    Jun 2011
    Quote Originally Posted by GSI2 View Post
    I have edited it, but only it goes out inside the message ...?
    Jun 2010
    This doesn't work in Xentry because there is no F2 button in Xentry.
  6. #5
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by e1nukke View Post
    And your Keyboard .. I guess you have the special type with NO F2 key as well
  7. #6
    Jul 2009
    i tried your solution. IT worked great with DAS
    but really in Xentry Diagnostic. I click the F2 button but nothing happen. It still show the Password and it require to fill the password. It only got Continue button.
    So, would u please explain carefully about that.
  8. #7
    Sep 2009
    Quote Originally Posted by nguyennhatquang View Post
    Most likely Xentry needs its own fix since the question is about a completely different part of the SW package. Perhaps experts can have a look at that too.
  9. #8
    impactops's Avatar
    State what options to select in sim mode that would bring up xentry password screens
    Step by step instructions preferably
    Regards
    Impactops
  10. #9
    Sep 2009
    Quote Originally Posted by impactops View Post
    Regards
    Impactops
    Seems there is no feedback on this topic. I'll give one likely example: for a 212.025 I run simulation with defaults except I select EU5 engine, 7Gtronic transmission and MY 2009 (should not make any difference but just in case it does) and then I select SRS control unit, version coding and configuration and special functions.
    Xentry asks for a password, the continue button is greyed out. If I enter a random password to be able to press continue, I get an incorrect password response.
    PS. I did not use English menus, menus may be called a bit differently.
    PS2. Anyone have the English thesaur file for 09/2011, why not the rest too?
  11. #10
    impactops's Avatar
    Thanks for replying DB_member, I have had a bit of playing around with to see where those menu's are.
    But i believe the one below is Gold!
  12. #11
    Jul 2010
    ... I have had a bit of playing around with to see where those menu's are.
    here is few more ...
  13. #12
    Jan 2010
    Only to change passfree file is not the right way to fix Passwords in DAS!
    I have a better Solution ! It overcomes all DAS Passwords for Cars and Vans
    and you don't need Offline coding. It overcomes Online coding like Offline
    (Only DAS not Xentry)
    Maybe that I can Fix Xentry Passwords in the next time too.
    Cheers
  14. #13
    Sep 2009
    Quote Originally Posted by shacky View Post
    Cheers
    I cannot see your solution. As long that I cannot see it, I don't believe it is better than the solution gcs190 shared.
  15. #14
    Jan 2010
    Quote Originally Posted by DB_member View Post
    What we can't see means not it not exist!!!
  16. #15
    Qrius's Avatar
    Aug 2009
    Correct , all those members that do share with each other unconditional,
    and did make DK as it is today , we can't see either. they allso exist !
    I guess you have more ebay then DK spirit.
