Results 1 to 7 of 7
    Member trycktill's Avatar
    Dec 2010
    casablanca
    Default golf 4 year 2001 101 ph Fuel Pump Relay (J17) faulty
    hello all i have this problem on golf 4 i need ur help
    Address 01: Engine Labels: 038-906-019-AXR.lbl
    Control Module Part Number: 038 906 019 KH
    Component and/or Version: 1,9l R4 EDC 0000SG 4901
    Software Coding: 00002
    Work Shop Code: WSC .............
    Additional Info: ''''''''''''''''''''''
    VCID: ,,,,,,,,,,,
    3 Faults Found:
    17932 - Fuel Pump Relay (J17): Open or Short to Ground
    P1524 - 35-00 - -
    18080 - Coolant Fan Control 1: Open or Short to Ground
    P1672 - 35-00 - -
    18027 - Glow Plug Relay (J52): Open or Short to Ground
    P1619 - 35-00 - -
    Readiness: 0 1 0 0 0
    Liteace's Avatar
    Mar 2009
    On a rock
    I would check wiring and earths 1st before anything else, unless all 3 relays are ~~~~~
    Meat-Head's Avatar
    Quote Originally Posted by Liteace View Post
    OUTBID:-
    1) What is the problem with this Gulf?
    2) Does the faults clear or comeback like boomerang?
    3) Do your hear the sound of horses running though the night?
    Dec 2010
    casablanca
    the wirings allready checked before and good but the fault come back after erase plz can give relay scheme to check it thanks for your help
    Liteace's Avatar
    Mar 2009
    On a rock
    Need the 6 digital sales code from the sticker in the boot for the correct relay scheme
    asmn's Avatar
    Aug 2010
    What engine code m8?
    Dec 2010
    casablanca
    the codes come back after test on the road with high acceleration the engine go to limp mode to make it in normale i have to stop and start engine 3 times or +
    where to find the engine code sir
    Work Shop Code: WSC 31414
    Additional Info: WVWZZZ1JZ4D019793 VWZ7Z0C7879870
    VCID: 67D65BEF2FF6
    3 Faults Found:
    P1524 - 35-00 - -
    P1672 - 35-00 - -
    P1619 - 35-00 - -
