fap 1.6 hdi no problem
HI . Please help remove DPF from dump ECU.
PEUGEOT 307 1.6 HDI
ECU 0 281 011 234 96 556 982 80 1039S05497 EDC16C3
ECU-SAFE 2.0 is deleted, but if car move distance greater than 50 km, ON reegeneration FAP procedure and ECU-emergency mode.
If this switch off the ignition, then again you can go without a problem 50 km ....
In configuration BSI filter is missing, ECU fuel additives is not active (physically removed).
Thanks in advance for any answer....
he must be joking
Pay for a real dpf off solution and stop wasting time and money with ecusafe. Then you will also have your proof...
There is a single value in the file which should be changed
are two ways to correctly disable the fap in 1.6 hdi-1.6 tdci
1) a switch-works perfectly no dpf or regeneration
2)8- switch no filter, no switches to filter mode fap-no readings by device diagnostics
3) is also another solution, but require you to enter immo
Thanks to all !!!
Very ineteresuet guru opinion about swiftec plz...
new flash with fap off
test and repor
you all banging on about ecusafe is sh!t and you all know better, then why not post a solution instead of loads of scare monger????
What are you replying for? you want money? if not then just post the solution instead of endless posts about how sh!t all our efforts are.
We can all download winols and ecusafe etc from here, but we may not all be experts on dpf removal, so offer your help or dont bother replying.
Thanks for f_all.
ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
please send solution
