antonypaul (18th June, 2015), DOCKERS (18th September, 2013)
I suppose that you need to unsolder it ( but I'm not pretty sure about of that )
Well if you have in mind to unsolder it and to use a very good adapter you can use something like this
QFP100 TQFP100 test socket programming adapter
BTW are you pretty sure that the S/N it is in this LPC2386 or in the LPC9107?
Good luck
I think S/N in I P89LPC9107=LPC9107?
See log ,then unsolder pin9 P89LPC9107=LPC9107
gordonjairo (11th August, 2018)
What's teraterm dump and what's out dump?
This is log question S/N in-out.
please can you to put here an tutorial how to make this
best regards
Hey, Sergej,
please be very carefully with putting serial number of your diagun public. There are for sure "launch spies" here, watching, and soon that SN will be blocked!
There also strong rummors that recently LAUCH changed software encryption for entire x431 line. So, no more alternative updates by just431.com?!
Or maybe you have Diagun from official dealer?
Regards and respect!
Open smartbox
Pin 2=RxD on Com-port-to pin Tx or to pin Rx in Smartbox
Pin 5-GND-to pin GND in Smartbox
Give 12V in smartbox or connect auto.
Cable connect Diagun.
Open HyperTerminal,set v=19200,
On Diagun,cable connect,Demo.
See log.
antonypaul (18th June, 2015), taxo1965 (22nd July, 2017)
it is possible to change sn number
download manual for microcontroller lpc9107
after that ou know what leg is
find one programmer that support those micro
connect programmer acording the manual .
for information micro has rx and tx
change the serial number what you wish and you must have the correct software
I see log in all pin LPC9107. This chip does not contain S/N.
