Page 3 of 13 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 194
  1. #31
    DK Veteran sergej's Avatar
    Latvia,Riga
    Yes.I think two times -open and coded.
  2. #32
    Junior Member anigrini's Avatar
    Jun 2011
    Default Launch X-431 Diagun Software Crack
    Okay yes it is great to change the hardware serial number but would it not be easier to alter / change the software by editing it and reloading it on the micro card? I have a universal standard X431 software which works on any Launch X431 but only the older type machines. I sell the Diagun and would love to give my customers regular updates......
  3. The Following User Says Thank You to anigrini For This Useful Post:
    karimdz (2nd November, 2018)
  4. #33
    Oct 2008
    On Earth
    Both method are hard to do.
    You have two choices.
    1. To change S/N in smartbox
    2. To change S/N in softwear.
    Both aren't easy.
    Good luck
  5. #34
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    Default Diagun
    Quote Originally Posted by eepromRipper View Post
    Hey guys, here you will find how to change a serial number on most x431 devices, i don't know about newer ones but i have been able to change and update the serial number of one gx3 and another x431 tool today.
    open up the launch and read the MPU on board "W77LE58" inside you will find the serial number and u can change it to whatever you want, if you can't do that, just send me your serial number and the file, i will edit it and send back to you
    I use TOP programmer but anyother programmer will do, beeprog etc.
    Hi mate - So can this be done without chip removel? I am told they do it that way in China if there any good anyways.
    YES some sellers do sell chip to resolder with new Serial number but I know it can be done without soldering etc.
    BUT I have no idea how to connect the smart box to get to the serial etc?>?
    Willing to advise whats needed etc?
    Thanks in advance
  6. #35
    Latvia,Riga
    Need name command or program for renumber S/N.
    Name command for display S/N "U??hO]0SWITCHO".
  7. The Following User Says Thank You to sergej For This Useful Post:
    MOBILTRONIC (29th October, 2016)
  8. #36
    Oct 2008
    On Earth
    Quote Originally Posted by sergej View Post
    You have to sure in which chip it is stored the S/N and then will be solution
    For GX3 we just know, in Diagun we aren't pretty sure.
    The there is few solution for programmers and softwear.
    Good luck
  9. #37
    The two uC, LPC2368 and LPC9107 are protected?
    If not, maybe we can read the content and maybe the serial is "in clear".
  10. #38
    NL
    Hi Is there somebody he have and wil share data with pass for X431 launch with 78le58f for the next year I have one but it has an 78L058 plcc 44pin (big mcu)
    regards Tony
  11. #39
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by Tachotony View Post
    regards Tony
    Hi Tony from NL
    Tako from NZ - Well was NL 30 years ago! How is work etc in NL? I am thinking I might come back see how things are etc
  12. #40
    any one can change sn or update diagun , please how to do it
  13. #41
    For sure, LPC 2368 nd LPC9107 are protected.
    Don't you think that Launch LTD engineers are so credulous?
  14. #42
    Mar 2012
    Thanks Alot Brother
  15. #43
    I have bought X431 heavy duty quit new from CHINA.
    But is not working. Seem software problem.
    I have 2 quetions:
    1)Does any body cans help me with new update for Heavy Trucks? Or cars?
    2) Can I install Trucks and cars software update on the same flash card?
  16. #44
    vwpassat,
    Why don't you call a seller first?
    Regarding your questions-
    1) you can buy soft here
    2) you can install trucks and cars soft on the same card, but only one part will work...
  17. #45
    If I should buy 2 flash cards, one for heavy duty trucks and other for cars, will it gone work?
    I did call already my seller but not so useful.
    Quote Originally Posted by AEN View Post
    vwpassat,
