Results 1 to 13 of 13
    Post mitsubishi colt key problem
    hi members. ave mitsubishi colt .1999.model 20001.petrol its ave problem of key and its use 4c key with immo box no G mr309674 ,x1t13971m with x24c01 .ecu noMD 346670,E2T69175 H7 .KEY data ID 4C - JMA TP02/TP07
    TIRIS Data: 7E 89 6C 19 05 00 00 00 00 69 33 7E .l try to use t300 it cant communicate with the car . this original dump from immo box .please l need to write key in to the dump any can help. thanks
    koncimobil's Avatar
    Sep 2011
    soxxi
    make new key with module99
    Default try this
    let me nw if it works
    i will try it from where?. immo or ecu?.
    it is your immo dump with new key in it
    l tray file but car not start.engine light it come and go off.
    ok now u need 2 make sure if it stays off... if it does stay off try and get diagnostics on engine to make sure theres no immo fault...if no fault codes stored then u might have some other problem on the vehicle too
    keygargoil's Avatar
    Quote Originally Posted by abuuauto View Post
    here try this key 1
    Sep 2012
    South Africa
    Default mitsubishi key add
    Could someone please help me to add a key
    Colt 2000
    24c01 attached
    Key Tiris data
    7E F0 01 71 05 00 00 00 00 30 3B 7E 00 00
    kiszka's Avatar
  11. The Following User Says Thank You to kiszka For This Useful Post:
    deondti (16th February, 2017)
  12. #11
    Sep 2012
    South Africa
    password??
  13. #12
    Jun 2020
    Namibia
    Good day
    I have a similar issue also a colt 2007 model the car does not want to start at all, I cant see whether it has a immo box on it. only a BCM/ECU that I can find, attached are pictures of the ecu.
    please assist me with thisWhatsApp Image 2023-01-11 at 08.03.28.jpgWhatsApp Image 2023-01-11 at 08.03.35.jpgWhatsApp Image 2023-01-11 at 08.03.41.jpg
  14. #13
    Jun 2020
    Namibia
    Good day
    These are the numbers on the ECU MB346670 E2T69177 H7 7424, JE331B33702B. The car cranks but does not start at all
