Page 50 of 53 FirstFirst ... 40454647484950515253 LastLast
Results 736 to 750 of 789
  1. #736
    Jun 2014
    Hi, got a dead F5S, and having read thru the whole of this thread, which is brilliant, im still stuck, "STB Memory error"
    (IF it comes with set STB memory error please run config.bat file (Located in folder you have downloaded and unzipped) ) before running loader
    Can anyone explain how to run the config.bat file successfully , then maybe i will get passed this point
    Cheers in advance
    mike
  2. #737
    P&D's Avatar
    Hi what cable are you using Null or USB
    If USB are you using the correct com-port ??
    also which software program there are a few
  3. #738
    Jun 2014
    Quote Originally Posted by P&D View Post
    Null via usb adapter on my laptop or Null direct via serial port on my PC, same result on both
    used several eprom update versions 2.0.0c and 2.0.1 and every version of .ABS i can find for original F5S and Clone F5S
    but i still end up here, with the stb, also been into device manager and slowed the buffer rate right down,
    and it still wont go
    so the qusetion was how do u run the config.bat file
    mike
  4. #739
    P&D's Avatar
    so the question was how do u run the config.bat file........ never had to
    Use one of these loaders.....
    erom_upgrade_8Mflash.rar
    Upgrade_PVR800_HD_Tool.rar
    Firmware below..........update20150713.zip
    Check your computer is using the correct com port.....see 1st photo com port
    this must match this com port see 2nd photo ....
    eprom update com port
    Tick boot loader & try again
    You now have all you need to get the box back up & running
    If everything works & then you get file mismatch you have a clone box
    which is a different firmware
  5. The Following User Says Thank You to P&D For This Useful Post:
    CrAcKeDuPII (18th August, 2015)
  6. #740
    Oct 2013
    Question
    Hi P&D,
    Thanks for all your help on trying to bring the boxes back to "life."
    I've got an old F3 that is constantly rebooting after a recent favourites update by USB. This isn't the first time I've seen this happen either. It eventually just stays on L100. Anyway I have used the null modem cable and have managed to complete the process of reloading the software several times, but the same fault persists. Just wanted your opinion......time to give it up as a bad job? BTW I have just about every loader and all versions of the software, but none seem to cure the problem.
    Cheers,
    CrAcKeDuPII
  7. #741
    P&D's Avatar
    Hi with the F3 are you using the correct firmware ??
    are you also ticking boot load on the screen where you load the firmware ??
    The last firmware for the F3 is below.......this is the one i always use
    where abouts are you if close i can do the box for you 10 mins top's
    or see DW190 post here ......http://www.digital-kaos.co.uk/forums...=1#post2189552
  8. #742
    Jul 2015
    Just wondering if someone could help me , I have a v5s open box and my father is looking for a box like this but I see that a newer version the v8s is out now ,would I be best off going for that box is there much of a difference and I guess it's the same set up , any help would be greatly appreciated
  9. #743
    Top Poster dazza78's Avatar
    Mar 2008
    leicester
    I've got the v8s and mine is stuck on strt booting screen where it says openbox, so I'm assuming I need to buy a cable ?
    Thanks in advance only had the box a yr and already had to sort anew server out after being scammed
  10. #744
    Dec 2013
    Anyone help me out please i had my friend bring her v8s box which was stuck with load on the front, so i flashed it. And now it dont do nothing no lights comming on nothing? Any ideas? thanks josh
  11. #745
    Apr 2009
    Quote Originally Posted by Hadron View Post
    Sounds similar to the problems encountered in this thread:-
    http://www.digital-kaos.co.uk/forums...idence-400956/
    It gets interesting from post #65.
    Anyone point me in the right direction for the above missing thread, I'm having the same issue with an S5f
    Thanx.
  12. #746
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by smspop View Post
    Thanx.
    It seems to have moved since I last linked to it.
    Here is the new link.
    Read from post#65 for the solution.
    http://www.digital-kaos.co.uk/forums...ht=coincidence
  13. #747
    Sep 2014
    thank you for this much appreciated
  14. #748
    Sep 2013
    Hi, can you install channel lists through this cable?
  15. #749
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by inaminute23 View Post
    Nope. It's for flashing (or dumping) the firmware only.
  16. #750
    Sep 2013
    Cheers mate
