Results 751 to 765 of 789
Threaded View
    Member darvash's Avatar
    Copenhagen Denmark
    Default Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked.
    Box does not respond or displays On or rebooting constantly ?
    If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow corrupt.
    You will need to use Skybox_openbox _flash_tool.zip, connect a Serial RS232 Null Modem Cable to the box and follow the instructions.
    Hopefully it will bring your box back to life.
    instructions
    Download SKYBOX _All_ Upgrade TOOL.zip or openbox_s9_s10_s11_s12_Flash_RS232_tool.zip if have older Openbox/Skybox
    Unzip this file
    1. Connect up your PC to the Openbox
    using a null modem serial cable.
    (Try to get a PC with builtin r232 port or buy a good quality usb to seriel adapter. Cheap adapters from flebay "do not" work at all)
    2. Switch the box OFF
    3. Run EromUpgrade.exe (Located in folder you have downloaded and unzipped) then check the
    com port setting is correct
    4. Select the latest firmware .abs file. (Download her if you don't have any)
    5. Select "next" then switch ON the box
    and follow the instructions to load
    and flash burn the firmware.
    6. If the process does not start, try
    various time combinations of switching
    the box ON after selecting "next"
    (IF it comes with set STB memory error please run config.bat file (Located in folder you have downloaded and unzipped) ) before running loader
    7. Don't switch the power off or disconnect
    while the download & flash is taking place.
    If your box keeps rebooting after updating so try software from http://hddvbsw.com/index.php?c=key_download
    If you cannot contact to your box check your null modem cable. Connections are like showen below
    pin 2 ...to... pin 3
    pin 3 ...to... pin 2
    pin 4 ...to... pin 6
    pin 5 ...to... pin 5
    pin 6 ...to... pin 4
    pin 7 ...to... pin 8
    pin 8 ...to... pin 7
    Important: Go into device manager
    <right click MyComputer--->manage--->on the left side u find device manager
    and check that you are choosing the right com port. If possible use computer with serial R232 com port built on mainbord.
    Have fun
    *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
  2. The Following 55 Users Say Thank You to darvash For This Useful Post:
    acres09 (9th February, 2016), ak005 (4th August, 2013), alwurzel (4th July, 2013), Arnather (8th June, 2013), BlacksunLE (7th April, 2017), Ch00ng (16th August, 2014), cooper 8 (7th September, 2014), dbj159 (13th October, 2014), fishy (31st December, 2015), fivesnakes (16th September, 2014), Gokhle (24th June, 2013), grim89 (26th July, 2013), happygrl (3rd May, 2015), harold566 (14th August, 2014), Holzwurm0101 (31st August, 2014), ili7107 (20th July, 2020), JDavid22 (27th December, 2022), jimbojimjay (1st October, 2015), jimmy230 (11th April, 2013), jimmynewbie (5th July, 2013), jolatacqce (26th August, 2014), jvcd100ek (20th November, 2014), kiko44 (7th February, 2016), kimosohara (25th November, 2014), lekir (18th December, 2014), Lucky1966 (21st April, 2013), mackin (28th February, 2015), mandarinas666 (4th May, 2014), Markymark49 (16th December, 2014), master28 (10th May, 2014), MAX2504 (20th August, 2014), miele (23rd June, 2016), Mysteriousguy (23rd August, 2013), paquito2014 (14th May, 2021), PeterAcko (13th September, 2014), polly4you (18th September, 2020), puente387 (8th July, 2014), rick2021 (8th April, 2014), rrodclos (29th June, 2013), saerhassan (21st March, 2015), stualdo (26th February, 2015), tunnaing52 (5th January, 2014), TurboPirate (28th January, 2014), undernaz (21st November, 2014), utdman (19th August, 2013), vincenzocarduci (20th August, 2014), vitormik (7th September, 2017), x1245 (23rd November, 2015), zfdesign (5th January, 2015)
