Page 53 of 53 FirstFirst ... 343484950515253
Results 781 to 787 of 787
  1. #781
    daithi's Avatar
    May 2009
    ireland
    39
    Downloads
    25
    Uploads
    Quote Originally Posted by maca View Post
    Get a new PSU off the bay mate or jsut buy a better box
    can you recommend one mate.. just for watching tv dont need anything fancy
  2. #782
    maca's Avatar
    Feb 2009
    liverpool
    486
    Downloads
    97
    Uploads
  3. The Following User Says Thank You to maca For This Useful Post:
    daithi (2nd March, 2017)
  4. #783
    daithi's Avatar
    May 2009
    ireland
    39
    Downloads
    25
    Uploads
    some reading in that cheers
    mate
  5. The Following User Says Thank You to daithi For This Useful Post:
    maca (2nd March, 2017)
  6. #784
    Hadron's Avatar
    Nov 2012
    E. London
    542
    Downloads
    87
    Uploads
    The S10 & S11 had problems with bad capacitors on the power supply board. They usually show up as having a bulging top. If the tops are not perfectly flat, then they need replacing. The usuall capacitors to go bad are ones shown with the red dot.
  7. The Following User Says Thank You to Hadron For This Useful Post:
    daithi (8th March, 2017)
  8. #785
    Dec 2016
    Downloads
    Uploads
    My openbox v8s is stuck on LOAD so im trying to unbrick it but when I try to download the latest .abs file from the link provided, it's not opening anything so can someone help me with the issue so I can start to use my box again?
  9. #786
    Nov 2018
    espaņa
    Downloads
    Uploads
    mi skybox m3 hd se queda con luz roja y no sale imagen ny enciende, alguna manera de recuperarlo, me hace falta el firmware de recuperacion, pero no lo encuentro en ningun lado, alguien me puede ayudar, gracias
  10. #787
    Nov 2018
    espaņa
    Downloads
    Uploads
    no lo puedo descargar
