Hybrid View
    Portugal
    Default sirius32 problem
    Hi friends.
    Can anyone help me with a problem with a clio 1.2 from 2003.
    I made immo off because all the wires and ECU burned and I inserted another one with immo off.
    Now the car doesnt measure the RPM and the temperature in the dash.
    Do you think it is because of the can lines and the file I am using?
    If so, anyone has a file for can to insert into the 29f200bb?
    Thanks to all.
    Best regards,
    Nuno
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by carsolution View Post
    Hi friends.
    Thanks to all.
    Best regards,
    Nuno
    Does central lock still work???
    How are uch???
    Maybe try to fix wiring .Move old 29f200bb over to new ecu and all will be well again.
    Am i correct that your ecu is sirius 32n ??
    Portugal
    Hi m8.
    The UCH is ok.
    The old flash eeprom I dont have it because it burned with the ECU and wiring.
    With the wiring it?s all ok, I think the problem is with the file I am using.
    If you have any file with immo off for Sirius32 with canbus to test, it would be great.
    Thanks for your time my friend.
    Regards,
    Nuno
    Hi m8.
    The UCH is ok.
    Regards,
    Nuno
    Hi.
    Did you tested with diag. tool can system.
    In alignment of network (units) or can error communication with all units,some error you may see.
    Maybe try to reprogram your new unit with original file(before immo off) and with the engine hot ( or simulate temperature)to see if you see values.
    Run starter engine and and see if rpm oscilate (200,300 rpm)
    DK Veteran teuton's Avatar
    Mexico
    Regards,
    Nuno
    I got attached file from the forum, can{t say if it will work for you. Try it.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Top Poster janeca's Avatar
    Hi Nuno, please give the total ecu part number maybe i could help you.
    Cumps
