Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Feb 2010
    South Africa
    Default X prog m and atmega 64
    Has anybody successfully used a Xprog m to read and write to atmega 64 ? The only " live" buttons I get are blank and erase .
    please advise me if there is a procedure , just purchased a new atmega for my cloned x prog m and want to load it with the
    firmware received from a fellow DK member . thanks guys
    Do what you can with what you have .
    Feb 2010
    South Africa
    After many months of battling with this one I eventually got it right . Xprog m's connecting diagram is WRONG .B0 must go to pin #2 and B1 to pin#3 on micro , repairs and upgrades here we come , regards
    vanos batam's Avatar
    Jul 2010
    Batam-Indonesia
    here your full dump from good X prog m
    _______________ D3-oToprog _________________
    ig : vanos_batam
  4. The Following User Says Thank You to vanos batam For This Useful Post:
    forumoto (2nd May, 2022)
    Jul 2010
    Batam-Indonesia
    here the schematic diagram
    ig : vanos_batam
  6. #5
    Feb 2010
    South Africa
    Thanks Vanos for the pic version of x prog . My post is about the atmega 64 version , I blew the micro doing something silly and after buying a new micro i could not program it , until i saw this error as posted above ,regards
  7. #6
    Holtek's Avatar
    Jan 2010
    Poland
    Set everything as the screen:
  8. The Following User Says Thank You to Holtek For This Useful Post:
  9. #7
    Top Poster georgegt's Avatar
    Apr 2010
    Romania
    Where can I find a good dump for atmega 64 ?
  10. #8
    Feb 2010
    thanks for schematic, my xprog-m is broken and I'll try to repair...
  11. #9
    Jan 2012
    Hi Friends
    Couple days ago i upgrade my xprog to to xprog box and probably You know what i have now..
    May some one help me... I need to know how to read ATm64 buy UPA... I see on pcb pin but when I tray UPA it doesn't see ATm
    I check pin on pcb to pin on 64 plcc but... upa had problem Could someone show how to connect ( which pin on pcb connect)
    Regards!
    ok now i read this AT but I see only 00000000000000000000000 in all flash.... what I did wrong___HELP
  12. #10
    ahadi's Avatar
    Sep 2009
    Quote Originally Posted by mtnt View Post
    Hi Friends
    Regards!
    maybe you couldnt read you could write.
  13. #11
    micromax's Avatar
    Dec 2009
    South Poland
    if you want read or write atmega by xprog you must create project by menu, next select file for flash, eeprom and config.
  14. The Following User Says Thank You to micromax For This Useful Post:
  15. #12
    Jan 2012
    no i use upa
    and i dont know how to connect which pins
    6 pins Vcc-52 GND-53 reset -20 msio-13 mosi-12 sck-11???????????????
    it's good ???
    Friends i need help my upa read only "0" and program the same "0":/
  16. #13
    tatop's Avatar
    Dec 2010
    italy
    no i use upa
    it's good ???
    i have egual problem
    sigh sigh
  17. #14
    Dec 2009
    Tengo la misma problema con 2 programadores..
  18. #15
    May 2009
    please write in englich
    por favor escribe en ingles
