Hybrid View
    Usa
    Default HOW TO TURN OFF. T-BELT ON TOYOTA
    1. Set the odometer ODO / TRIP TO "ODO" , and bring the ignition key to OFF
    2 While pressing the trip meter, remove the ignition key in the ON position and hold on for 5 seconds.
    3 Release the odometer button, then press again this button within a period of 5 seconds.
    4. Switch to T-BELT (timing belt) so that the values ***8203;***8203;of a following initial settings appear I'ecran:
    km: 15 (0.000km)
    mile: 9 (0000 mile)
    5. Inserting the setting value in case of replacement
    Press the odometer button as many times as necessary for every 10000km.
    For example, if your meter shows 15 (150000km), you change the belt and you display 25 (250000km) on your counter.
    If an interruption of more than 30 seconds occurs during I'operation adjustment, the changes will not be valid, odometer return mode "ODO" and the system in normal mode.
    6. After introducing the new value to replace the belt, hold the trip odometer button in the ON position for 5 seconds minimum. Then ensure that ODOMETER will return to "ODO" and the light goes out.
    Ashraf6119's Avatar
    UK
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Meat-Head's Avatar
    HI
    YES THIS IS ALSO WHAT YOU DO WITH BEDFORD MIDIS AND ISZU TROOPERS, AND POSSABILTY ISUSZU PIASSA.
    JUST A CHANGE OVER MICROWSWITCH WHICH CHANGES AFTER 50000 ISH - GOOD IDEA, IF BEEN WORKED ON BY JUSTY22 - WILL MEAN LIGHT WILL COME ON WAY TOO EARLY OR WAY TOO LATE
    HTH
    MEAT
    Liteace's Avatar
    Mar 2009
    On a rock
    HI
    HTH
    MEAT
    Maybe the light will go out when justy22 give it a haircut back to below 50k
    Meat-Head's Avatar
    Quote Originally Posted by Liteace View Post
    is that haircut 50 or haircut 100?
    smokey08's Avatar
    Essex, UK
    It depends which jumpleads have been used
