Does anyone know how I can enter this mep code correctly into my 8100 and get my bb unlocked??? I have 1 attempt left and am very nervous about doing anything. I do have the imie and the mep codes for the phone.
Before you attempt this check that you have a valid unlock code!!
1 - Go to Options Menu > Advanced Options
2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3 - You will see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
4 - Enter the unlock code.
Go here m8,
FreeMyBlackBerry.com
I used on monday , and was unlocked on tuesday
and its fee
I did what you said and the personalization screen came available it says sim disabled network active network subset disabled service provider disabled corporate disabled?????? and after I entered the mep code i have 0 attempts left????????????
you need to find a dealer with a DM3 to reset the phone now, i cant understand why you rushed into it when you can get the codes for free on here. the codes that you get on here work 100%.
out of curiosity can you post the phones details imei and mep and also the number that you tried putting in 10times. this way we can tell you where you went wrong incase you ever want to unlock a blackberry in the future.
regards
imei:359675014041340
mep:-04104-007 this mep is the number I tried on my last attempt and obviously it was not the correct code I needed?????
Is there any other way to reset the mep counter besides taking it to a dealer????
You could send it to blackberry.
The Mep2 code should be 1988514272429118
I would advise you to find a shop that has DM3 access & pay to have the counter reset.
After that you can enter the correct code & unlock the phone.
Once you have got it unlocked you should be shouting from the roof tops that patience is a virtue & not following site rules can cause stress & hardship
Canker
"Animal, vegetable or mineral... I'll do anything, to anything, with anything"
- The Baby Eating Bishop of Bath & Wells[COLOR=Green]
no that isnt the code to put in, that is the phones Mep code we use this to generate a unlock mep2 code from the phones mep and imei.
if you do need it to work on a different network your gonna have to sell that one and buy another second hand one.
rule of thumb if a code doesn't work first time then have the code checked again. its not worth taking to a dealer just sell it and get another. blackberry's are cheap
